1 - 20 of 22 Posts
My starter motor is squealing intermittently, doesn't turn the engine and sounds like it is disconnected from the engine - just spins on it's own. This happens once, then I try again and everything starts normally.
Does the starter have a clutch? Could this be the problem? Can it be reconditioned or does this require a new motor?
So far this has happened twice in the last 2 days. How long do you reckon I've got until it doesn't start at all?
Thanks
just go and get an exchange unit from your local auto leccy its just a sticky solenoid (not engaging) cant determine how long it will last had one like that in my old cruiser (holden v8) and is still kicking now (12 mths on) lol
Just bought one off ebay for $330,auto elec localy wanted $560 for the same unit & says he's never had any probs with them,turns the motor over alot quicker than my old one,motor starts as soon as i turn the key.
Original from Nissan around $900.
Just thought i'd share this if you decide to buy a new one.
a good auto leccy will be able to rebuild it for you others might say just replace it.
But for 300 bucks the one from ebay sounds ok.
would probably cost you a couple of hundred at least for labour to fix yours
link? Thanks
Don't know how to do links,doo,but if you search for GQ starter motors on ebay there are a few at different prices.
Chinese probably,actually there is no brand or country where they are made printed on them.I asked the seller where they were made & he said they can come from a variety of countries,he wasn't sure,mmm,a bit strange.
Came with a 12 month warranty,so we'll see how it goes
Thanks - found what I think you have got.
Think I'll probably get a new one and then keep the reconditioned old one as a spare.
Still not sure what the solenoid does though!
The solenoid is the smaller unit (usually cylinder shape) mounted on the starter motor body.
It has 3 basic functions.
1. When you turn the key to start it supplies the large amount of current (via the battery lead) to the starter motor.
2. It also pushes out the starter motor pinion so it can mesh with the flywheel.
3. Once the vehicle has started and you let go of the key the solenoid will also help disengage the starter motor pinion from the flywheel.
Really?The one i bought was totally sealed.I looked right over it to find any way of water getting in so i could silicon it up before i fitted it but looked to me as there was nowhere for water to get in anywhere.
Before spending all your hard earned cash... Take off the little earth wire on the top, clean it and screw it on nice and tight. I had a problem just like yours, it was just a bad earth to the solenoid.
like jeri said, the earth wire is a dodgy little sod, mines wobbly as hell and had been playing the same game as described for a couple of years now.
i bought a second hand spare when it started it, its still in the shed.
and that one, the earth wire has been entirely soldered into the unit.
but yeah, id expect it to last indefinately, mine seems to be.
nissan patrol y60
I bought a new one from john at gold coast 4x4 i think it was 440 inclusive but has 3 yr warranty
Your starter problem won't be the solenoid, still could be an earth problem unlikely though
Solenoid "pulls in " then motor is powered by a set of contacts in rear of solenoid, so if starter motor spins solenoid is working.
More likely to be pinion gear on starter sticking or worn and not engaging with flywheel ring gear, pinion gear should be easy enough to change, if not to mechanical study a manual and give it a go
hey guys i have a tb42 efi engine had the one way clutch die on me hunted around looked on ebay was almost going to buy thru repco for $300 ended up buying one from work forklifts run the same motor and only cost me $180 12mth warrenty
Right Turn Clyde
a word of warning if u get a non gen new 1 and do alot of water crossings be prepaired be replacing it in 4 months time
Yes they dont appreciate the water but if you pull it out and clean the brushes and armiture etc every now and then they go alright. Its just like everything else on a 4by when we go playing in mud and water, a little preventive maintenance and it will last. Its a common fault that the brushes seize in their housing. I strip mine every 2nd oil change, only takes 1/2 hour and all is good.
Discussion Starter · #20 · (Edited)
So, the $300 ebay motor is now in the car, and the hitachi motor (OEM?) is on my desk in several pieces.
The solenoid pin is moving freely, and the original problem was motor spinning but not moving engine. So I think that is OK.
The lever arm is also moving well, and the pinion shaft moves forward quite easily.
The pinion gears look worn a little, and I've attached a photo to see if the brains among us think they could be the problem.
I'm wondering about the clutch that connects the pinion to the motor shaft. I am able to spin the pinion clockwise with moderate resistance while the clutch gear stays static. Is this normal? How can I tell if the clutch is faulty. How would I replace the clutch if it is faulty?
The original symptoms were intermittent, about 1 in every 3 starts, and only once at a time. Retrying the start worked every time, and the engine turned quickly and without any odd noises.
Am I right in thinking the clutch is at fault?
(enjoyed getting my hands dirty on this - thanks P4x4 for giving me the confidence to have a bash!)
1 - 20 of 22 Posts
