1 - 20 of 124 Posts
Td42 turbo diy from scratch "FINISHED"
Hey all
been thinknig of doing this for a while now so i started yesterday by making my manifold, i was going to build a J pipe but i actually worked out easier and quiker to build a minifold, next things to do is get a T3 flange to adapt the VG30turbo to the Mani, i also bought all my 3" tube and U bends to build the exaust as soon as i get the turbo mounted. then wory about the cooler piping oil and water line later, JUST WINGIN IT
i am planning to have this finished within the next couple of weeks so ill do my best to capture progress and share it with ya.
nissan/swb gq
Looks good , well done for having a crack your self .
I you cant see it in the pic's , but I assume you put a V ( weld prep ) between all the
but-weld's on the T-pieces and the elbows . .
Keep us updated on how it all come's togeather
cheers mate, Yeah as i had to cut the T peices down i did end up rebeveling the ends before i fully welded it.
nissan/swb gq
from who/where did you pickup the manifold flange ? .
pacemaker/autopace in jandakot according to them it was one of the last in WA in there system. but im sure they make them up. cost me $90 through muffler mike in WA
Discussion Starter #8
long radius 50mm steam pipe. with 50mm tees.
heres some pics of the mani 99% complete just needs abit of a quick clean up. mokked the turbo up yesterday and you wouldnt belive that a SS 3" dump pipe from a skyline fitted in snug and spot on.
it will be a low mount
Discussion Starter #10
i think it has somthing to do with using a water jet cutter they have to start from an edge maybe. not sure really
Discussion Starter #11
quick update, bit of a Mock up and the dump pipe
Discussion Starter #13
well the mani and exaust has cost me $420, the turbo will be around $200 the cooler and pipe will cost me nothing as i already have most of lying around, and i am unsure what the oil/water line will cost to get made up. should be able to have it all done for less than a grand hopefully including the EGT gauge
That looks good. Very simmilar to how my manilfold was made. Awesome work.
Discussion Starter #15
Cheers Mate
finished the dump and also started on the rest should have the exaust done by tomorrow
Right Turn Clyde
Doing well. I was considering going down this same path untill I came across a factory setup.
What stamping is on the turbo? V1, 2,3 ,or 4?.
Discussion Starter #17
that turbos a blown RB20 job jus using it for a mock up the VG'sand RB's have the same flanges
Discussion Starter #18
Ok well the exaustis finished i forgot to take a photo of the tail end of it but the one below is from the g/b cross member to the diff, and i also got the cooler mocked up alowing room for a thermo fan.goint to build the scoop next and a turbo sheild, i shoulld have most of my oil and water lines done tomorrow and i get the RB25 turbo on tuesday, come next weekend end ill be done hopefully.
From my experience. The Rb25 turbo is pretty good, Mine is set to 12 psi, but below 2000 rpm wont get above 5 psi, and 2500 rpm gets to 9 psi. I am thinking of trying an Rb20 turbo for more bottom end pull.
And what cooler is that?
1 - 20 of 124 Posts
