I am looking at a Tubo upgrade for the TD42 in a 2004 Series IV GU and found a series of Garret Ballbearing Turbos on offer the 2860, 2871, 2876, 3071 & 3076.
I am running 285 70 17 which is about 10mil larger diameter than standard and have found over all the vehicle is far too high a ratio needs more power across the whole rev range so I will be looking at upgrading the intercooler as well with 3in mandrel bend exhaust.
Which turbo? I have heard the larger the turbo the longer it takes to spool up. Ideally I would like the Turbo to be spooled up at 1700rpm but delivering maximum torque.
Is bigger better?
Now ideally if I could convince the handbrake and had the money perhaps the $35,000 to put in the 6.5 supercharged Chev Diesel putting out 820Nm. Gotta have those dreams!!!
Is bigger better?
