1 - 9 of 9 Posts
2004 Gu S3 TD42t
Hi all,
just after some information. I've purchased a mechanical 11mm rebuilt pump to be placed onto my silvertop.
I've sent this to the mechanics and they have had the patrol for nearly 7 days finally have installed the pump and cannot get the engine to fire up it turns over but not firing. is there anything missing here ?
10mm mechanical pump exchanged with 11mm compensated. would this just be timing issue ? any help would be appreciated as this seems to be a relatively simple swap over.
Should be simple enough. I would just be looking for the usual faults.
Surely a competent workshop can sort this out, rather than asking their customer. It would not give me confidence.
1988 Maverick TD42,
We can't really help when you don't have the car.
  • Does it ignight at all or just crank without even spluttering
  • Are glow plugs connected and working
  • Is the fuel solenoid working
  • Did you bleed the pump
  • Is fuel coming out the injector rails on crank
  • Are the rails connected in the right order
  • Did they line up with Z or ZZ timing mark
2004 Gu S3 TD42t
Thanks for the replies everyone.
after a long wait time and disappointing news i was told the IP was damaged and this was the reason it was not starting before they could uninstall and send off i had the car towed out of there and sent to my friends workshop.
I had the car towed out and changed the pump and I've done the timing myself using a few workshop guides and videos was a rather simple process once i got my head around the indicator tool once all complete and back together she started up. roughly 6hrs of work being first injector pump installed
since then i have had the car dyno and tuned and everything is running sweet.
I do now just have to check my glow relay as cold mornings they suck to start but this will be this weekends next job.
2004 Gu S3 TD42t
everything above was addressed once i got the car back and I believe they didn't time or bleed the pump during the steps on install so i started from scratch and done it all myself
Good news mate.
I am stunned that a workshop could not do this simple job.
Mate I'm interested in what was actually wrong with the pump. Maybe the incompetent workshop actually damaged it.
2004 Gu S3 TD42t
I think it come down to timing as I got the pump timed and lines installed and started in a few hrs then the following Monday morning booked into dyno tune and still runs mint 👌
1 - 9 of 9 Posts
