1 - 3 of 3 Posts
It will bolt on, but how well it will work will depend on whether the engine and pump are set up for a turbo, as I think a 99 model pump may or may not be boost compensated depending on model.
99 GU pump will work well on the GQ if you have a turbo fitted. You will need to connect the boost compensator of the pump to the inlet manifold so that the pump can feed more fuel in as the boost comes on song
Reactions: TB42 Patrolman
1 - 3 of 3 Posts
