hey all
in the process of reputting back togeather a ht18 turbo onto an engine and half the bits and pieces are missing.
my main question is what happens with the oil return. is it run onto a screw in barb to the side of the block just above the sump or into the sump itself. as this is the main bit missing.
and also the boost compensator on top of the fuel pump. i can only assume the pipe goes into the intake somewhere as well as this is what lets it know when to lean off fuel and what not.
cheers for your help and if anyone has any pics would be great just so i can get a rock solid answer to make parts hunting a tad bit easier.
cheers.
cheers.
