TD42T valve clearances
10K views 1 reply 2 participants last post by  gudc98
I am about to do my valve clearances on a GU TD4.2t and need to know if they are done hot or cold. I searched and found 13 to 14 thou is the go but no one says what temp to do them at. My GQ TB42 I always did hot but not shore on the GU.
#2 ·
Hey dude,
these sites and quotes may help
3) Valve adjustments should be done with the motor cold.
.10 and .12 would be OK if set when engine is cold ..
I have the Nissan A12 factory manual. It agrees with 1200rc:
Hot:
intake: .35mm (.0138)
exhaust .35mm (.0138)
Cold:
intake: .25mm (0.0098)
exhaust: .25mm (0.0098)
But Clymer and others say don't set it cold -- always Hot. When I used to do it, I did .013 in. cold, they were quiet. I always looked for a semi-tight fit (some drag, not loose, but not a really tight fit).
A12 valve clearance [Forum - Classifieds] : Datsun 1200 Club
check/adjust valve clearance hot or cold - Honda Foreman Forums : Rubicon, Rincon, Rancher and Recon Forum
Valve Clearance Adjustment - XY200GY Shineray
Hope this helps you,
Good luck.
