In no particular order as I've noticed them on the photo:
Fuel pump, A/C compressor, both manifolds, turbo.
If you're not going back to having the Ti EGR system, there are a lot fewer parts to worry about.
After that, engine mounts (if you don't have TD mounts on the chassis already), flywheel/flexplate (manual vs. auto), lots of bolts for gearbox, etc. Clutch.
PCV hose to your intake manifold (via a catch can if you want).
Timing cover plate for fuel pump.
Coolant hoses for heater. Also, depending on the turbo you choose, you'll need to alter the turbo water supply arrangements to suit. Get rid of that Frankenstein hose thing on the front.
Oil feed and return line for turbo (will probably be supplied with your turbo if you get a TD specific kit).
Gaskets and/or gasket goo as needed.
Can't see well with the photos - starter motor may be needed as well (try and get a genuine one if you can, they just work better).
At least your rear main and welch plugs appear to have been done recently, but while the motor is out, I'd be getting to every part that is a pain to get to while it's in the engine bay. I would probably suggest taking the sump off and re-sealing it - some people try to do the rear main without re-establishing the sump seal, which tends to lead to oil leaks. Sometimes you get lucky, generally you don't.
Close up the intake/exhaust holes and give it a good clean, so you can find that bastard of an oil or coolant leak when it happens.
