1 - 11 of 11 Posts
Hi all has anyone had issues with a td42ti clutch slighhtt slip when its cold when taking off? Its fine once warm. Any ideas?
Stating the obvious, it indicates something is wrong. How many km's has it done??? It may simply be worn out.
Only brought the car recently was told it had a new clutch in it. But hadn't noticed the slight slip till recently so I feel like it's kinda just happened recently
Did they have a receipt, unfortunately some of the undercover details can't be checked, I thought it was the other way round and would slip If hot
Check and make sure the fork has free travel/slack,when the pedal is up,[cold] and again when hot,if so,it would seem the shlippage is a worn driven plate,can't think of another scenario,c'mon Lee,what d'y recon ?When it is hot,stick it in 2nd gear step on the brake and let the clutch out steadily,what happens ?
Had a bit of a look today. I could push the fork in with my hand, is that normal?like it was stiff but I could do it. Also when I let it go it slowly moved back to original position, I thought it would spring back quicker
If I do that, it stalls lol
I'm no weakling,but there is no way I could push the clutch fork in against the cover plate springs,and it should return sharply when pressure is released,so it seems the cover plate is stuffed [ or you are a descendant of Lou Ferrigno ] you are pushing the fork forward towards the engine yes ?
Yeah mate that's correct, towards the engine..
So I changed the clutch fluid yesterday afternoon, and this morning when cold I have not noticed a slip once..
Could it have been the heat from the exhaust ruining the fluid? I dont have a heat guard around the exhaust there and its a 3inch
Excess heat will destroy fluid,I also have a 3" exhaust,made a heat shield up to fit around,just allows air flow and deflects heat,even a few mm clearance will make a difference.
Discussion Starter · #11 ·
Awesome sounds like the go. Any chance you could show me how you've done it
1 - 11 of 11 Posts
