Status
Not open for further replies.
1 - 19 of 19 Posts
Links within contain valuable information for ZD30 DI owners (and CRD owners) both new and old. Info will be added as it becomes available. Some threads have their roots in the main GU/GR section. This thread is to be read in conjunction with the archives in the General Patrol Discussion section. Please PM me if a link does not work or PM me if you think of a good inclusion
Geeyoutoo
NEWBIES NOTE
1. Please Search for information before posting a question, this helps reduce repeat questions, a common problem. Search can be narrowed by doing a Custom Search, some patience is required.
2. Help us help you by adding info about your vehicle, this can be done in your signature line, model, engine, etc. Your location can be put in the upper right hand corner where your post count is, this info helps us understand your situation a little better from a point of view of access to spares etc, without extra posts asking where you're from. To do all this go into User CP (upper left corner of any page in the menu bar) to access the above info input menu.
Read on, hope the system helps you.
Here's a place to start which explains NADS and the often misrepresents facts about the ZD30DI, what to look for and what to avoid.
Discussion Starter · #2 · (Edited)
Discussion Starter · #3 · (Edited)
Post 3 NADS
Post 3. NADS
NADS
NADS stands for "Nissan Anti Detonation System" This was developed by many learned guy's on the forum to combat the issues with the early ZD30 DI's. The first post is a brief description of NADS, the logic behind doing them in a series of steps and the reasons for the modifications, also a notation on heads. Not a "how to" as that info is available on the forum in volumes with a search, a good deal of it on this page. Once you have finished NADS you should be able to qualify for this ZD30 Heat Shield Removal Laceration Club :)
NADS Step by Step guide to doing NADS mods by Dronus.
Dawes Valve Dismantle and Adjustment - YouTube
Intermitent Limp Mode At the start of each winter we get questions about intermittent limp, it's called cold limp.
Dawes-Devices 3 Bar Racing, The original Dawes, needle valves and multi stage boost controllers etc.
Dawes Spring + Optional HD spring install Steps Info about and Instructions for fitting and setting up the optional HD spring to a Dawes valve.
DV-06: HYDAC Optional needle valve for Dawes installation.
Exhaust Gas Recirculation (EGR), NOx and particulate measurement | Cambustion A brief look at the EGR system for new members, EGR articles always espouse that the EGR valve contributes to cooler combustion temperatures, my experience was the opposite, my EGT dropped by more than 25c after my EGR blocked itself, go figure.
Nissan Patrol ZD30 Engine Problems
What Makes a Grenade a Grenade
Manual Boost Control Set Up Options Post 27 has a brilliant description by whitie of VNT/Needle setup reasons.
Discussion Starter · #4 · (Edited)
Post 4. MANUALS & PAPERS BOSCH VP44
Post 4. Manuals and Papers Bosch VP44
VP44 Injection Pump Manual There are 6cyl and 4 cyl versions, this covers both including the ZD30DI. There is not a lot of info on the web about our 4 cyl version but there is a lot of info re the US 6 cyl version. Lift pumps were a common addition to some US trucks around 2000, due to extra load, which didn't have them as standard, a lift pump does wonders for ours as well, giving a good boost to low end torque. Look in "Modifications"
BOSCH VP44 INJECTION PUMP AND LIFT PUMP FAILURES EXPLAINED - Diesel Bombers VP44 thread from a US Diesel Bombers Forum with some interesting points.
VP44 Diagnostic Another US VP44 article with a number of tests, codes are obviously different to ours.
Injector Pump (Bosch VP44) Calibration Local comment on VP44 calibration, what can and can't be done.
EDC Removal Instructions - Bosch VP44 - YouTube For the more adventurous.......
Lift Pump Help Mainly about effects of lift pump on VP44 cooling, the pressures spoken of are higher than I would like but they seem to have no adverse effect. US 6cyl VP44, basically the same pump with 2 extra rotor points and outlets, same electronics.
Longer Life For VP44 More on lift pumps.
Discussion Starter · #5 · (Edited)
Post 5. MANUALS & PAPERS Garret VNT (GT2052V)
Post 5. Manuals and Papers Garret VNT (GT2052V)
Garrett | FAQ Garret page with some good base info.
VNT15-Turbo Not the same turbo we use but similar, an interesting read of the strip down and how it works for the uninitiated and new members. There is an interesting animation of the NGV/VNT operation at the end.
Garret Statement
Garret Non Repair Bulletin Garret VNT bulletins, read and make of this what you will.
Turbocharger, VNT, and diesel turbo FAQ | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum Interesting general VNT turbo info.
ZD30DI VNT Aircooled Turbo Teardown I got hold of a damaged turbo and stripped it.
Post 6. MANUALS & PAPERS - TRANSMISSION
Post 6. Manuals and Papers - Transmission
A bit of info on LSD's for the uninitiated, there are many types, Eaton just seem to have the most information out there and for my money (if I had that much) the E Locker would be my choice of weapon, excellent diff but expensive.
Detroit Locker - YouTube
Lock Right Locker - Part 1: How it works [HD] - YouTube
Exploded View - Inside the Eaton TrueTrac Differential - YouTube
Exploded View - Inside the Eaton Suretrac Differential - YouTube
How Eaton's E-Locker Technology Works - YouTube
Airlocker operation - YouTube
Ashcroft Air Locker - YouTube
Also found this helpful item on fitting an LSD to the front of your GU yourself:
How to fit a diff locker in a GU Patrol - YouTube
Discussion Starter · #7 · (Edited)
Post 7. MANUALS & PAPERS - ENGINE
Post 7. Manuals and Papers Engine
Low Water Alarm Sensor Save your engine when sudden coolant loss occurs.
Discussion Starter · #8 · (Edited)
Discussion Starter · #9 · (Edited)
Post 9. WORKSHOP MANUAL DOWNLOADS & PAPERS - GENERAL
Y61 Workshop Manual to Supp 23 no password necessary as this is now on a storage site I use to send docs out, try it, no preview is shown for PDF.
Y61 Workshop Manual to Supp 15 Some may prefer this version as it is easier to negotiate, again no preview.
D22 Workshop Manual Navara Manual, no preview, download only.
PLEASE IMMEDIATELY INFORM ME IF LINKS FAIL.
PartSouq This is a very handy site, put in your VIN and vehicle details will be shown as well as various parts descriptions in the area below.
WorkShop Manual in Italian Supplied by Slowman65, download from post, thanks mate.
The Bible Colour
Cooling System Bible
Body Tech, Early GU
Patrol Parts Manual LHD/RHD 1987/2007
Autotech Common Rail WorkShop Guide Not specifically for our CRD's.
Eaton/Harrop ELocker Installation Manual
How a MAF works
ECUTalk Userguide.pdf
Coolant Fundamentals
How a Cooling System Works
Diesel Smoke Explained
Diesel Smoke Explained 2
Discussion Papers on Diesels. Thermoguard
Diesel Lambda sensors for common rail systems Base general info on injection for diesels.
Off-Road Driving Basics | The Art of Manliness Even though it is written by a Toyota Guy and I don't necessarily agree with everything, it is still an interesting basic read for people new to the game.
Barbed Hose Fitting Chart For those special projects.
Decibel - Wikipedia, the free encyclopedia Understanding the decibel range for those straight through exhausts ;).
Vehicle Standard (Australian Design Rule 13/00 – Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles) 2005 Amendment 4
Discussion Starter · #10 · (Edited)
Post 10. MODIFICATION THREADS
Installation of the CRD engine
Small Barn Door Won't Stay Open, Here's a Trick.
GU Small Barn Door Strut Mod
Swirl Valve and Throttlebody Mod
Jaycar Digital MAF Voltage Modifier + TurboSmart Fuel Cut Defender (FCD2) Different methods of controlling multiple and singular MAF limp modes
JayCar MAFv Modifier adjustment tips video.
Water Injection for Diesels + Water Meth Injection on a ZD30, what results?
Fuel Temperature Including fitting of coolers and technical data.
ECUTalk + ECUTalk Instal (click on each pic) Best money you will spend (see post #9 for ECUTalk User Manual).
ECUTalk Consult Software Now Supports Diesels.
Cross Country Intercooler Install ZD30
Provent Drain Automated
Dawes Valve Setup Options
Dawes Valve Dismantle and Adjustment Video
Dual Dawes with Needle Valve Setup Video
Adjusting VNT Grubscrew (click on each pic)
Carter 4600HP Lift Pump Install[/COLOR] Includes spill line mod and complete parts list.
Auto Trans TC Lockup Switch + Line Pressure Solenoid Dropping Resistor
Engine Temperature Sender, Aftermarket
High flow MAF sensor housing and Airbox upgrade
Elocker Install, GU Front
Converting Auto Hubs to Manual, Pictorial
Ideas for location for relays and fuse blocks
Exhaust Heat Shield Removal Problem (tongue in cheek)
GU Flares removal, repairs, tips & tricks Interesting tips on Flares and cleaning mud from behind them.
Aftermarket Cruise Control with OEM SW switches panel Good write up on Cruise Install.
Increasing standard main/sub tank capacities
Boost Control VNT Vacsol VNT + 3 Needle Valves
Central Locking Install (GU 2007 DX) - Supercheap Auto Kit
Discussion Starter · #11 · (Edited)
Post 11. MAINTENANCE THREADS
Post 11. Maintenance Threads
Why All The Talk Of MAF Cleaning ?
3.0l fuel filter change Don't forget the small "O" ring under the fuel filter housing.
ZD30 oils and coolant guide A survey of our members on oils and coolants.
Cleaning Coolant Expansion Tank couple of good tips here
Saving your ZD30 Tensioner from Failure A common failure when a lot of mud is played in. (Just ask Deccers).
Belt tensioner ZD30 - strip and lube NOTE* Considerable care needed when disassembling, contents under load from a heavy spring, injury may result from careless handling.
ZD30 Y61 Belt Tensioner Bush - Drawing
MAF Cleaning Important part of maintenance on a ZD30, many of us clean the MAF at each 10,000 service interval.
Coolant change. Coolant change has lead to significant problems for some of our members, this gives some ideas and outlines danger areas.
ZD30 Coolant Drain Plug Location bloody hard to at leta lone get out.
How much oil required for ZD30 "with or without fillter Change Straw poll General discussion on oil changes, how much is used, circumstances when draining, brand and weights, change intervals for different modifications, good enlightening read in addition to the "Oils ain't Oils" thread.
ZD30 exhaust manifold gasket removal Good advice re manifold gasket replacement.
Body mount question. Could be some traps in doing this job, worth reading.
Body Mount DIY A second body mount thread from DIY.
Handbrake drum adjustment
GU Changing Thermostat (ZD30)
removing heater core
Small Barn Door Won't Stay Open. See post #12 for a fix without fitting a strut.
Small Barn Door Stay Open Fix Without Fitting a Strut.
Bloodless headlight bulb change
Discussion Starter · #12 · (Edited)
Post 12. GEN INF THREADS - POLLS AND SURVEYS
Post 12. Gen Inf Threads - Polls and Surveys
EGT Survey ZD30DI (Part 2) See first 3 posts. Summary of the old Survey, Auto's (post #1), Manual's (post #2), Data Template (post #3). From the summaries you will not only find what EGT to expect from your DI with different modifications and transmissions, but you can also find the most popular gauges, exhaust systems (brand and size), egt probe mounting position etc, etc.
ICV% Survey (ECUTalk) Data on VP44 possible relationship to pump life and efficiency.
[FONT=&quot]How many K's has your ZD30 DI done? if rebuilt when did it blow? add 2nd round of K's A WIP survey of K's on DI engines.
What life did you get from your Alternator An ongoing poll on alternator failures.
Bosch VP44 IP, how long do they last on average? Ongoing poll re the lifespan of the ZD30 DI Bosch VP44 Injector pump
ZD30 Grenade, Definitive Blowup Poll An ongoing poll on ZD30 engine failures.
Solid Flywheels and ZD30 engines An ongoing poll on DMF v Solid Flywheels.
ZD30 Original Clutch Life As the title suggests.
preferred diesel Fuels. BP Ultimate Diesel/ULP a bit more info on BP ultimate.
Coolant Temperature Survey Survey of coolant temps across the board.
[/FONT]
Discussion Starter · #13 · (Edited)
Post 13. GEN INF - ENGINE / TRANSMISSION / HARDWARE
Post 13. Gen Information - Engine, Transmission, Hardware
ReMapping the DI ECU A long thread with twists and turns that was started before it could be done, At post #104 we start to see some action. Mine has been done for a long time now and it is great. Have put this in both mechanical and electrical sections as it suits both.
Diagnosing and Rebuilding 2003 ZD30DI Jakes rebuild.
How to fit a Cobra Head to the Airbox.
Replacing the Airbox lid seal cheaply and effectively.
Towing in 5th Gear Discussion on 5th gear failure with pre 2002 GU's (Nissan modified the box in 2002) which is quite common, particularly when used for towing, post #41 has some good pics that visually explain the reason.
Increasing the size of the IC inlet tubing.
ZD30di rebuild [worklog] Rebuilding a ZD30DI from scratch, heaps of pics.
GU 5th Gear Failure
How synchro rings work First post has an interesting vid on how synchros work if you don't know.
GU Small Diff/LSD Syndrome. Diff info, how to read what you have.
Sump plug thread? A little confusing at first, but the sizes of both sump and diff/gearbox plugs are contained within.
ZD30 Air Filter - which way up? Eternal debate about which way the air filter is fitted, in short... Lip Seal Down, reasons contained within.
Oils ain’t Oils An in depth look at engine oils, very good info, if you take the time to read the thread, like a lot of threads good info can be buried in the banter.
ZD30 oils and coolant guide Bit of an oil and coolant guide based on peer info.
Inside the ZD30 If you have never seen inside a ZD30 you can here, some good info.
My zd30 rebuild... A new members rebuild with lots of good informative pics, well worth the read.
Bosch VP44 ICV%, what does it actually realy mean?
Issue with VP44 Injection Pump General info on a Bosch VP44 fuel pump problem.
Help - another overboosting problem A lengthy read on how a small limp issue developed into a humungous exercise, the data collected along the way is well worth catching up with. Page 9 is where it starts to come together. Info includes common issues with VNT vacuum & adjustment, MAF voltages, boost readings and stock vs modified characteristics.
head gasket One members experience with what turned out to be a cracked head and gasket failure.
Result of EGR mix with breather oil in ports Discussion on gunk that forms in the throttle body etc and moves onto things like sump levels, dipstick part numbers and lengths, good info with international input.
2 stroke oil in your diesel fuel A long and winding thread.
Engine Warm Up Discussion on practices.
Intercoolers, the Pros and Cons of various brands. As the title suggests.
ECUTalk ICV % ??? One member chasing an issue with VP44 low Idle Control Valve %. Followed up by a survey of members experience, see Surveys and Polls.
Water cooled V non watercooled Turbo? Air/Water cooled turbo, Nizzbits contributes on changes.
Changing out a Water Cooled ZD30 Turbo? A Simple Guide And Some Tips
Protecting against Poor Fuel Quality in remote areas. Interesting thread relating to recent topical bad fuel and ways to beat it, I have a Mr Funnel and it is great, if you buy the big one and add an extra section of hose or chop up an old concertina funnel you can fill straight from the pump.
The CORRECT way to Calibrate your speedo
K&N Air Filters
Gearbox oil synthetic GL4 or GL5 answered.
Video on tailshaft angles and vibration.
Serpentine Belt Removal zd30
Oil dipstick problem, crimped end fell off.
ZD30 Additional Fuel Filter Options Detailed info on optional extra fuel filtration.
ZD Rebuild can we make it better, stronger, faster
ZD30 Engine lifting points and attachment
How to repair a leaking (or oil spitting) Air Locker step by step
Mystery Screw in my Engine Sump? Interesting read, more common on the CRD than the DI though
ZD30DI Manual >-< Auto Conversion
Discussion Starter · #14 · (Edited)
Post 14. GEN INF THREADS - ELECTRICAL / ELECTRICAL COMPONENTS
Post 14. Gen Inf Threads - Electrical & Electrical Components
How to Code Keys to a New ECU
Fault Codes, ECU
Glow Plug Timer Mod ZD30DI. Later model Kemo 113A wiring
Strange Dash Warning Light Behaviour Dash Light problems.
GU boost gauge power Wiring into dimmer
Fuse problem HELP!!! Engine control fuse, what it actually controls and the final result.
Zd30 ecu pinouts list of pinout numbers and locations.
ZD30 starts difficult One of our European members had a cold start issue, some good information on glow plug relay fuse near the end.
Possible MAF mod A different approach to a limp problem, well worth the read.
How do I Install a Crank Angle Sensor
Glow plugs - why the missing tips ????? Strategies for enhancing glow plug and possibly engine life.
Earth Strap - Hallelujah Praise the Forum...1 This is well covered in the bible, which should be compulsory reading for any zd30 owner.
ECUTalk - Consult LCD Display
ECU Talk Conversion Mod to In Dash
Labelling Wiring Harness Ideas
Relay and Fuse Block location Ideas
Airbag Light Reset Procedure Door switch referred to in the fix is the switch in the door jam that operates the interior light.
ZD30 Alternators, same between all models?
Eng shutting down and high idle
How to test all MAF's at home
problem with my Drivers windows when cold
Alternator Wire Broken at Plug Info on fixing broken plug wire.
A/C switch light removal
Auxiliary battery - lowest acceptable volts b4 recharge?
Autron Cruise Control Installation Instructions
Problems with indicators
Wiper Motor, How to Remove Wires From Plug
Aircon Fan Switch Issue
Solving Key Reader Issue
Electrical Wiring 102 Reverse Worklights
Discussion Starter · #15 · (Edited)
Post 15. GEN INF THREADS - STEERING / SUSPENSION / BRAKES / Safety
Post 15. Gen Inf Threads - Steering, Suspension, Brakes and Safety
Poly or Rubber Bushes
Drop Boxes How do I Fit Them
One Man Operation Brake Bleed Nipples.
Death Wobble Final Fix Poll
Death Wobbles Fixed! There are many threads on wheel wobble if you search but this one is quite good and the guy gives a good write up in the first post.
Preventing rear suspension mounts cracking.
Crack in GU Steel Wheels.
GU Changing Brake Rotors Step by Step
Brake Bias Adjustment
Helpful vid on disc removal GQ but that's OK.
DIY - Installing a 2 Degree Castor Bush kit
How to Service Your Brake Calipers 101
Cargo Barriers, Who's Using Them
Calculating Shock Length for Lift
Discussion Starter · #16 · (Edited)
Post 16. GEN INF THREADS - ENTERTAINMENT / NAVIGATION
Post 16. Gen Inf Threads - Entertainment / Navigation
Off-Road Navigation A good read on most aspects.
Discussion Starter · #17 · (Edited)
Discussion Starter · #18 · (Edited)
ANNOUNCEMENT ON MANUALS AND DOCS IN POST #9
GE.TT, to which I have numerous electronic manuals for patrols and components like VP44 etc, seems to be down, also I cannot contact them for some reason so am going to wait a few days to see what happens, if I need to find a new storage site it will take me time to get all those manuals back on line and entered back on the forum.
Discussion Starter · #19 · (Edited)
ANNOUNCEMENT ON MANUALS AND DOCS IN POST #9 Part II
Site still down so I will assume it has gone bye bye' for good. After trying many sites and having issues I have gone for Google Drive, gives me 15gig of storage over the 5 I had before, another issue with that site was large manuals like the ZD30 to supp VX would disappear after around 500 downloads, never got a satisfactory answer on that, I'm hoping large manuals will stay up forever now. Based on this assumption I have loaded the larger supp XXIII manual (it is available through my signature link as the last one was), it covers '
all' models of the GU series. You may need to experiment a bit when opening sections to feel your way through, loading these manuals from this end can be tricky as I've found a few times over the years.
I've had a Y62 manual on my laptop for a couple of years, it is massive at 680mb or so, getting that to load and be readable has and still is a nightmare, I'm not sure anyone here would use it anyway as Fakebook seems to be the preferred method of communicating for Y62 owners, if someone would like it to be loaded PM me and I'll persevere, otherwise it is not worth the effort.
Am working my way through the various sections to update manuals and docs that have failed. I currently have 15 on Google Drive to share.
Ross
EDIT: Should anyone wish to have the Y62 Manual, PM me and I will forward a link, it is not easy to negotiate hence I haven't posted a direct link here.
1 - 19 of 19 Posts
Status
