1 - 5 of 5 Posts
Howdy.
Temperature gauge doing weird things!
Sometimes drops off completely and sometimes actually reports the correct temp (about half)
Ideas?
Thanks,
Dave
If you like to have real info about your engine, instead of repairing your factory gauge buy an ecutalk display (about $220). Among many other things it will tell you the real temperature of your engine, whereas the factory gauge is designed not to scare the horses and stays at the one position between about 75C and 105C then it starts to go up after that
Sweet - Where can you get them from?
The nutty professor
if it is a bad connection on the temp sender then it would give a bad reading on the ecu talk aswell,
Might just climb behind there and check cables and crap to start with - Those ECUTALK's look frigen sweet!
Might throw that on the birthday wish list!
1 - 5 of 5 Posts
