1 - 7 of 7 Posts
Hi does anyone know how to test if a compressor still works? Ive got an air con compressor from a toyota coralla and want to rig it up just to inflate tyres as needed with a switch incab to turn it on when i need to. Dont want a full endless air setup just yet. Appreciate your help
poweer to clutch wire and earth to body should make both the pully and the clutch plate turn without slipping.
u should be able to turn and feel resistanbce, hear oil slurping and air being pushed out the discharge port. if its off a coroola a fair chance it will work they r reliable
thanks for that info, i'll give it a try. Does it matter where the power comes from? Eg can i use the power wire from the stereo just to try it? Im not to sure when it comes to this stuff. Thanks, phil
So i managed to connect a 12v power wire to the compressor, was something meant to happen. The compressor isnt mounted in the engine bay. Does it need to be attached with a belt off the motor to spin it? I dont want to have to pay $$ to get it tested to see if it works.
connect the wire to battery pos and conenct the body of the compressor to battery neg(earth) and the clucth should pull in and "click"
worked a treat, thanks guys. The clutch slipped and and when i spun the pulley there was resistance and could hear air noise etc. Now just need to work out how to mount it in the engine bay and hook up a belt.
1 - 7 of 7 Posts
