I have been playing around for a while now trying to make 200rwkw with my setup.
Its not the most preffered setup to get there though, and i'm just trying to do it with the current turbo for the hell of it.
It's purely been about making the 200kw number.
Its a 99 gu ute with close to 400k km on it and a factory turbo engine.
It has a united fuel injection 12mm pump and I'm running a 56trim 2871 with a .64a/r exhaust housing.
When I first put it together it had the standard .6a/r compressor cover and made 194rwkw @ 3080rpm and 675nm at around 2200rpm from memory on 26psi on a 265 tyre.
I then fitted 285 tyres a different intercooler and a different intake manifold and lost power. 183rwkw and only 600nm.
I have since changed the compressor cover to a .5a/r , changed air filter to a panel type(gen 111) and down sized the turbo to intercooler piping from 2.5" to 2".
I got it back on the dyno today and am fairly pleased with the results.
It made 193.2rwkw @ 2920rpm and 688nm @ 2200rpm.
Peak boost was 30psi but the way it gets there is really funny, it has 7.5psi @ 1600rpm and then hits 25psi @ 2080rpm, but doesn't hit 30psi untill 2320rpm. Not very good at all.
The driveabiltiy with this setup is not all that nice.
Sunday the plan is to put the .6a/r cover back the turbo. Since I last had it on there I have done a DIY type surge porting to it. Surge was one of the reason I changed it. Will be interesting to see how it goes.
I also have a .7a/r housing ordered (surge ported), just want to try it to see how it goes.
I'll back the boost back down to 28psi with these covers.
At the moment though I think I have found the limit as to what rwkw I can make.
I just can't get it to pull above 3000rpm on the dyno. I can get it to pull to the govener on the road but not on the dyno. If anyone has any ideas here I am all ears.
If I could get it to pull a little higher on the dyno I rekon it would make the extra 7kw I'm looking for.
I have a few other things I want to try, but will update this as I get them done.
Marty
Marty
