With everything going on last year, time was in very short supply.
It took me over 12mths to get a new head finished for Bitsa. Its not exactly how i wanted it in the end, simply because I wanted to drive it again, and with Christmas coming up, I simply ran out of time to do a few things.
My intention was to get everything I could possibly get coated, coated, this did not happen, I also intended to run some direct port W/M injection, this did not happen either.
My engine is purpose built at a rather low compression for an IDI engine, 17.7:1, only issues this presents is starting, just need to glow it 2-3 times. Other than that the engine does everything very nicely.
Fuel economy is great for what it is etc etc.
My new head has a few ideas going on, one being the use oversize valves simply for the reason it allowed me to run bigger throat diameters and totally opposite valve seat angle arrangement than is typically thought to be ideal for a low revving diesel, e.g. my actual seat angle is 49deg.
This new head also has extra coolant holes drilled into it and a few other things going on.
My intention when I fixed it was to run the same test BB TD05 based turbo I have been running for the 4yrs or so. Mind you, this turbo had gone through many many compressor wheel changes and being a little impatient when testing at times I never balance them when I just swap wheels over, its not like I am concerned if I break it, I have spares if need be. But Tuesday arvo I did break the turbo, pity, it was rather responsive for the size it was.
I just happened to have a bigger turbo, intention was to run this at some stage and see what power figure I could actually make, I wasn't concerned with not hitting one of my goals of 1000+nm with it, as long as it made power.
Tuesday night, I did actually do some runs to 4000rpm on diesel only, never done this before, motor was never built to run diesel only. Surprise surprise, I did a few runs at highish 800nm and peak power rather high in the rpm for a TD, like 250rwkw at 3998rpm on a couple of runs, bit of gate adjustment and lowish 900nm and 250 odd rwkw at 3200rpm.
I was happy with that as a base.
Filled the W/M tank yesterday arvo and got the boys to do a base run for me to 3000rpm while I was answering phone and next minute they are in my office happy but kind of concerned.
To all of our surprise it made 292rwkw and 1030nm by 3000rpm, power still going up, but the engine shut itself down, OOPS.
Luckily it was just the lift pump losing power (must fix this one day, its really not good for my pump).
They didn't want to run it anymore so I jumped in, reset dyno to do a run to 3300rpm and made a small adjustment to the W/M.
302rwkw @ 2963rpm, and 1072nm @ 2344rpm.
WOW, to be honest, I never thought that was even possible for what it is, its a daily driver/tourer, like New Years day just for the hell of it I went for a drive and did 1200km or so just for something to do.
Sooo Happy Days for now I guess.
