Righto ladies and gents, my beloved grenade has developed a rather annoying hooting sound at speed which I can not, for the life of me, figure out.
The sound is difficult to describe but sounds a bit like an owl is stuck on ("Hoooooooooooooooooooooooo"), or perhaps someone blowing over an empty beer bottle (Or a holey piston?
) and is worst at about 100km/h @ 10% throttle. I always thought it was the snorkel (Sounds like it comes the front-left), but the girlfriend with her head out the window reckons it comes from the back.
It has always made the sound when you back off and coast under light throttle (E.G. down a hill) and will shut up if you accelerate or drop to 0% throttle, but now it seems like it is greatly amplified. It's mainly got me irritated because a) It's really farking annoying on the freeway and b) I hate not knowing what it is.
I've checked:
I did clobber the exhaust tip when 4WDing, but this didn't start when that happened and there has been no change since I fixed the exhaust tip. No other damage to the exhaust is apparent.
The volume of the noise seems to be largely dependent on vehicle speed, and is barely noticeable under about 90km/h, although if I listen carefully I can still hear it when moving through gears... It changes slightly in tone with engine speed changes.
No other problems, noises or changes in behaviour have been noticed. Apart from the "hoooooo" it still makes its usual noises and still goes like an obese bat out of hell.
The only other thing I've noticed recently is my front crankshaft seal seems to have sprung a leak in the last few weeks... Probably unrelated but worth mentioning in the sake of completeness.
So, if you have managed to read all that... Any ideas? Anyone had a similar thing? Or can anyone at least tell me what causes that "hooooooo" sound so I know where to look?
Don't think I have a signature any more so it's a 2003 GUIII ZD30, 3" Exhaust, Dawes/Needle valve, EGR Block, swirl valve disabled with 267,000km on it.
Cheers,
Thomas
I've checked:
- Air intake / snorkel - Snorkel was leaking in the guard but re-sealed and no change.
- Changed air filter - no change, if anything it's louder.
- Can't see any exhaust leaks, joins are all tight
- Turbo is still making it's usual whistling and whirring noises and the hooting doesn't seem consistent with when the turbo is working.
- Intercooler is a yum-cha ebay job (Was meant to be a temp 12 months ago) - doesn't seem to be leaking.
- Ran out of ideas and checked diff and transmission fluids - all good
Cheers,
Thomas
