Why ?Hmm ok I'll sus it out! 16's would be nicer..
Lighter = better handling and cheaper tyresWhy ?
The higher the negative offset means a wider wheel track.yeah i was looking at his other comment about uncertainty with 17x9 -6 offset. The 16x8 will be a -12 offset making the 17x9 stick out further
but the 9" rim will be out a further 12.5mm so an extra 6.5mm over the 8"The higher the negative offset means a wider wheel track.
I am running 17x9 -6 no probCorrect but the 17x9 is wider so it would poke about 6mm more that a 16x8 -12.
I was more concerned with rubbing on the inside with a -6.
Gotcha.Correct but the 17x9 is wider so it would poke about 6mm more that a 16x8 -12.
