Bit of a demonstration I mocked up of how the shackles should sit when I relocate the hangers. It'll be stronger too since they'll be just under the crossmember:
Yep after a little thought I’ll likely pull the engine out, put new gaskets and seals through it, check for cracks in the head while it’s off, put it back on anyway because I can’t afford a new head, and then hopefully the whole thing won’t leak oil out the sides, rocker cover gasket, sump gasket, and rear main.Make a list of the jobs that need doing, then work out which job (or which set of jobs) needs doing sooner: engine or transmission. Then rip that one out.
Happy to helpYep after a little thought I’ll likely pull the engine out, put new gaskets and seals through it, check for cracks in the head while it’s off, put it back on anyway because I can’t afford a new head, and then hopefully the whole thing won’t leak oil out the sides, rocker cover gasket, sump gasket, and rear main.
Dunno if I’ll bother putting the N/A in temporarily while the turbo motor is out, I’ll probably just end up driving the family around commodore again for a while.
It needs some love too, oil change is due, give it a wash, get a new tire because I took slightly too aggressive of a racing line around a corner and clipped the rear wheel on the curb (whoops); y’know normal things…
Gearbox on the patrol isn’t as much of a concern, 5th gear is pretty whiney, so I’d say the teeth are getting pretty worn out, but it’s nowhere near as easy to fix as new gaskets in the engine. Assuming it all goes smoothly, that is. Which I don’t have a history of to be fair. Worst case I accidentally do irreversible damage to the motor and throw the turbo gear on the N/A while I look for a new SD33T, or just look for other engine options.
In any case, it’s the engine that needs leaks fixing, so it’ll be coming out regardless. Maybe I’ll hold off on getting the clutch itself until I know the engine is all good.
Wow brain dump in a reply. I did kinda write that as I was thinking so my thoughts just laid themselves down on the screen lol
In my trade, we would call it ‘Writing a first draft’. 🙄🤣🤣Yep after a little thought I’ll likely pull the engine out, put new gaskets and seals through it, check for cracks in the head while it’s off, put it back on anyway because I can’t afford a new head, and then hopefully the whole thing won’t leak oil out the sides, rocker cover gasket, sump gasket, and rear main.
Yeah, usually you’d edit that to be more concise but apparently I didn’t think of that at 12:30something am…In my trade, we would call it ‘Writing a first draft’.![]()
Oh I just realised I never answered your question, honestly, I didn’t notice a big difference in power or torque, which is backed up by a recent dyno run I did where I made about 3hp more and it was hard to judge extra torque because the previous run was done before the regear.Well done. The above line interested me, but when I got to the part that said previously you would have backed off at 80k to keep EGT in check, my doesn't answer the question I would ask, was there a torque improvement noticed along the way. That is what my CCIC did more than anything else.
