In other news, I installed a new RTC steering dampener, and also put castor wedges between the leafs and axles last night since I did the extended shackles…
And holy mother of christ the death wobbles on my test drive.
It’s always had a shimmy at around 70-80, but this was something from an entirely different planet. I’ve seen it described perfectly in another thread before, it feels like the car is going to violently rip itself apart and doesn’t stop until you come to an almost complete stop. I see why they’re called death wobbles now, if you weren’t expecting it or didn’t know how to control the vehicle once they started, you’d be very likely to be in a bad accident. Luckily my instinct was to brake and pull off the road into the grass on the side, so I’m all good, but I was pretty shook (literally and figuratively) after that.
I have never experienced something like that before, and it was the scariest moment I’ve ever had driving a car.
sigh
Anyway, now time to go about looking for the cause.
Obviously the first thing to try is the castor wedges, since it never happened before I put them in (thick side to the front, to tilt the pinion down, same as castor bushes or drop boxes in a coil patrol), but in my head that doesn’t make much sense, since castor correction doesn’t usually result in death wobbles, and almost always helps reduce road shimmys by putting the steering geometry back into alignment. So I’m going to leave them for now.
Next suspect would be steering dampener, since that was the other thing I changed recently. However this unit is a tough dog rtc danpener, which is recommended for most leaf sprung vehicles, and before I installed it I noted it had better dampening than my old factory one, so it shouldn’t be the cause.
Next I just checked the kingpin bearing, as hinted in my post before, as it was loose. I took a shim out and put it back in, now it’s got preload again and the wheel doesn’t have slop, but just went for a test drive and got bad wobbles after hitting a bump going around a corner at 50, so no go.
I checked the front tyre pressures, both within half a pound of each other, so not unequal pressure.
Next I’ll be putting different tyres on to see if it’s a balancing issue, but it shouldn’t be because it’s come out of nowhere (tyres still have wheel weights attached), but I’ll try anyway.
U-bolts are tight, did them up last night when I did the castor wedges.
Shackle bolts are torqued to spec.
Now I’m a bit lost
