Don’t we all. Not mine but one identical.What I will say however is that in another 20+ years you will have regrets, I have those feelings about a vehicle I had in the 70's, they come back to haunt me from time to time.
The cheapest option you have mentioned is learning to weld. Do a little reaserch on rod sizes and materials, don’t go too deep, get some general type rods and learn to strike an arc, then start running some beads. Get comfortable with this before trying to join materials. Moisture in your rods is a huge problem, that will cause difficulty in striking your arc. A small bedside cabinet with doors and an incandescent light, even an old bar fridge with the light going is a cheap (free) dry cabinet for your rods. A decent mask is imperative, there’ll be blokes on here that are professionals that can recommend what to get, some protective clothing, cotton and wool don’t melt into you, there are decent cheap leather gloves and aprons about. A bucket of water to drop your spent rods into (metal bucket), it can also be used to put out some fires.
After you have learned the basic, then you can practice some joins. YouTube will be your friend as will the advice from this forum.
Have fun.
Yep, I bought it a couple months ago off a guy who’d put a UFI on, so should be in good condition as long as it was an upgrade not a fix. Only spent $150 on it so even if it’s just to get the mounting sorted I’m ok with that. I can make the actuator move slightly by sucking air from the diaphragm chamber thing, and the shaft play seems good side to side, no in and out.Do you have a gt2052?
Ohh I didn't know Nissan made water cooled ones, if I were to hazard a guess I'd say since the turbo is cooler there'd be less strain on the oil cooling system (of which the SD33 is known to be laughably bad)? I might even pm you to discuss that one anyway, sometime in the future, even if this one does turn out to be good, because to me at least water cooling sounds like a good thing. I forgot to mention another thing I'll have to sort out, sooner now that I'll be playing around with extra air and fueling, is an oil cooler to mount up the front. Shouldn't be too hard, either get an adapter that fits on the current oil filter housing and has external lines, or find some other way of doing it.If you have any issues, I have a couple of gt2052's in the shed, one water cooled the other air cooled.
You will get many different thoughts on this, yes all DI's were water cooled turbo's up until 2002 sometime. It doesn't add anything other than a temperature stability, Personally I think Nissan dropped it for expense reasons, when you know all your models you can see where little things were dropped to save money. The eclipse come with ability to run water cooling and even though it is a pain in the arse to remove a water cooled turbo from a DI I wanted to keep it and I know another highly respected fan of watercooling on here. I did a small mod which I wrote up in my build thread so now I can disconnect the water cooling very easily and have the trubo off in 1/3 of the previous time and no need to remove second battery.Ohh I didn't know Nissan made water cooled ones, if I were to hazard a guess I'd say since the turbo is cooler there'd be less strain on the oil cooling system (of which the SD33 is known to be laughably bad)? I might even pm you to discuss that one anyway, sometime in the future, even if this one does turn out to be good, because to me at least water cooling sounds like a good thing. I forgot to mention another thing I'll have to sort out, sooner now that I'll be playing around with extra air and fueling, is an oil cooler to mount up the front. Shouldn't be too hard, either get an adapter that fits on the current oil filter housing and has external lines, or find some other way of doing it.
Totally agree mate, learning to weld is the most cost effective option. If you're after some good advice on where to start and what to go for in terms of welding gear e.g. gloves, aprons I'd definitely recommend the guys at Alphaweld. Have found them really useful over the years whenever I've needed advice. Here are their contact details: Contact the ExpertsThe cheapest option you have mentioned is learning to weld. Do a little reaserch on rod sizes and materials, don’t go too deep, get some general type rods and learn to strike an arc, then start running some beads. Get comfortable with this before trying to join materials. Moisture in your rods is a huge problem, that will cause difficulty in striking your arc. A small bedside cabinet with doors and an incandescent light, even an old bar fridge with the light going is a cheap (free) dry cabinet for your rods. A decent mask is imperative, there’ll be blokes on here that are professionals that can recommend what to get, some protective clothing, cotton and wool don’t melt into you, there are decent cheap leather gloves and aprons about. A bucket of water to drop your spent rods into (metal bucket), it can also be used to put out some fires.
Have fun.
Seems like a good option, from what I've read proper sound deadening is supposed to absorb and stop the sheet metal vibrations, and that 50% coverage should be enough to stop that. In saying that I really want to make it as good as possible, so I'll probably try to get as much coverage as I can.I used this stuff.
I can't imagine its much different to the car builders product.![]()
PingJing 30 sq ft butyl rubber sound deadener
BUTYL RUBBER SOUND DEADENING is used to reduce panel vibration which will reduce road noise, improve sound quality from your audio system and moresoutheastcaraudio.com.au
Also used this on the roof and inside the doors and rear quarters.
53.8ft PingJing Thermo-Acoustic Liner + Premium Application Roller + Australia Wide Courier Delivery
This a a high density thermo-acoustic foam primarily used as a high performance replacement for carpet underlay to further reduce road noise and heat. Normally applied to the interior on the firewall, floor, inside rear guards, roof and doors, but can also be applied to other areas including...southeastcaraudio.com.au
I went pretty light on the application, only covering about 50% of the large flat panels. I also avoided going over any body seams so I can keep an eye on any rust issues.
