Awesome job. I imagine that helps take a lot of the gremlin issues out of the equation then?Yes using the same systems is a lot easier then ever imagined. I have even programmed the nats ti br fully functional so all standard features work
And no shredded diffs to be seen lol.Here's a small vidhttps://cloud.tapatalk.com/s/5bdd0c461f5af/20181103_102354.mp4
Sent from my SM-G960F using Tapatalk
YetAnd no shredded diffs to be seen lol.
Can only do a half throttle take off other wise it blows the tyres off. Matched with a early 1st gear change.About 8 seconds to 100klm eh. I was expecting 6 at least hehe. My crappy old TD will do that with a bit of effort. lol
A bog stock ti 62 will do it under 7 easy.yeah mate i was expecting you were feathering the throttle a bit, those V8 do a bit better than 7 sec pretty easy.
A stock 62 ti will do high 14’s low 15’s.Cheers gents, I have been ripping around in it today and the looks people give you is sooo bloody funny. I had a gent at the servo look at it front to back and looked a little puzzled. Mind you running it straight out the cats makes for some loud motoring thats for sure. Have a feeling I will need to change the tcm as I dont think the current one likes it much and being nissan it wont be able to be tuned through the software i have available. The tail pipe section arrived today so i can build the rest of the exhaust this week after hours and get it down the drags wensday for a few runs. Providing I'm not sleeping out the trap and i can crawl it out of the same one, I cant see why it wouldnt do a mid 14 given the 400m speeds I have been seeing ;-)
Yeah mate a ute. My sons GU experimental EFR6758 will easily breaks 8 sec closer to 6 if water methanol is activated. My own GQ ute is a bit different, its 500kg's lighter and a lot more bits to make torque a bit differently. It may not break 6 due to gearing but it would certainly be very close with pre turbo Water/Methanol. Maybe one of them efr's would crack that 6 sec, due to instant transitions they are well noted for.Is that a ute?
It SHOULD pull mid 14s sleepingA stock 62 ti will do high 14’s low 15’s.
That thing being 400kg lighter should do low 14’s easy.
Nothing like power to weight hoggy.Sorry to be OT, but shissen!
Didn't know a TD could go anything like that.
