Ga'day,
Well I have been dabbling in these for the last 8 years, and found that yes the rolling sleeve is the far better option over the bellows style, as the rolling sleeve will dampen itself, where the bellow will act like a pogo stick.
As Geordie well knows there a limitless combinations you can go with these.
Ive always kept it simple, bags, 1/4 air line, Schrader valves. But you soon learn that that wont be enough, as you have the car at the height you wont, but then you fill your tank up and the extra weight can be the difference of an inch in height.
I currently run a sort of simple setup rolling sleeve airbags, 1/4 air line, with inline Schrader valves t'd into 4 electric valves connected to my compressor, and I use a wireless key fob to control it. It was a pretty cheap setup considering.
You need to choose what style of piston, narrow soft ride for light car or wide piston or hour glass piston. I chose the hour glass piston for my current setup as its heavy and tows a lot, and works a treat. the 5422 is a pretty good all-round bag good for up to 3"lift.
When you get on truck springs have a look at the information pdf and it will tell you there recommended design height, but remember when choosing your bags to factor in your mount height.
Mounts are simple, I have made mine to be able to pull out like a coil if needed, the air bag man kit I believe requires you to weld the mounts into place which can stuff you up if ever needed to throw some coils in.
There recommended lifespan is approx. 7 years, which by 7 years a coil would have sagged.
I have only ever blown 2 bags, one was trying to look like a tool and lowering it down too low and went around a corner too fast and had a bottom out and pinched the bag between the mounts, the second was down in Tassie doing the clymes track towing a 2.5ton van and the mount was loose and spun changing the offset and on full compression rubbed on the top trailing arm mount, which was probably my fault for not tightening it up.
All of my travelling is remote,highway, through padocks and so on, so don't let people use that excuse on you for not going that way, some mates of mine used to run them in winch challenge trucks doing OBC & Cliffhanger and never popped one.
I hope this helps some its the best I could do with a yelling missus and a screaming kid
