This is what tjm had on there site about them there were pics to but im not sure how to put them on here.
TJM TIGER ADJUSTABLE SHOCK ABSORBERS
NOW AVAILABLE
TJM Equipped - On and off road work or play 4 wheel drive equipment
model: tjm tiger
From the consistency of bitumen roads, to the rugged terrain encountered in the outback – TJM
Tiger adjustable shock absorbers will provide unwavering performance for every situation,
providing you with the ultimate control. Simply adjust for optimum performance to seize the
track ahead.
Engineered and tested in Australia, you can share the confidence, control and raw attitude
invested in each big bore, 9 stage adjustable TJM Tiger Shock. For the complete terrain solution
– TJM Tigers will tackle every situation with mastered precision.
1. Seamless Billet Mounts
The strongest possible construction available.
2. High Performance Viton Seal
Smooth action and long lasting durability
against leakage.
3. 18mm Hard Chromed Shaft
Strong, hard to bend & tougher against
Australian conditions.
4. Next Generation High Density Foam Cell
Increased comfort and performance that is
built to last.
5. Massive 40mm Piston
The large internal bore assists performance.
6. Big Bore 60mm External Reservoir Tube
For increased oil capacity, improves heat
dissipation and reduces shock fade.
7. Nine Stage External Adjustment
With a simple adjustment it gives you the
flexibility to suit varying terrains.
Tiger struts feature an adjustable spring seat
for fine tuning ride height.
