1 - 5 of 5 Posts
Hi All,
I have a LD28 engine that i am currently trying to get running.
I think that the timing may have slipped. Is there a way i can confirm this?
GUII ZD30DI Wgn
Moved from classifieds to tech section. The 2.8 engine is covered in the genuine workshop manual that is available in post #9 of the DI archives.
GUII ZD30DI Wgn
Hi All,
A bit more info would help,why do you think it slipped ? I don't know LDs,but check if it is an "interference engine" before you start winding things over.I just watched a bit on you tube,and the top end looks close to an L series petrol.The timing chain has a locating mark which aligns with a mark on the cam drive sprocket,the chain has a hydraulic tensioner which must be held in place if you take the sprocket off the cam,or it will move out of place,is this likely ?
1 - 5 of 5 Posts
