Hi people, read a lot of stuff on here about tires, so I am assuming (a dangerous habit) that some of you know what you’re on about. Currently I have stock 2006-ST rims (Ali) with 275-65-17 factory tires.
Have not had the truck long and took it down the beach for a bit of fishing and the bloody things cut into the sand like a hot knife in butter with 25psi inflation, had to drop them to 15 to keep going.
The beach is open to the southern ocean, so is not hard, or even firm, packed sand, quite the opposite in fact. I have seen snakes getting bogged down in it…
My old 2002 4.2TD GU had 285-70-16 BFG RT-TA’s that loved the sand, prior to that my 80 series 4.2TD cruiser had Long Trails and even those hi-way warriors could deal with it, but these buggers hate it.
I don’t want to go with pure off-road skins as I also tow a 3.4t boat up and down the west coast, so hi-way wear is my main concern and I don’t want to change the stock ST mags. Was going to swap over my 4.2TD rims & tires, but the aftermarket rims don’t clear the calipers.
What I want to find out is what is the maximum width of tire I can squeeze on to the rims. My local guy says he can put 285’s on them easy, but I was wondering if I can squeeze a set of 305-60-17 BFG RT-TA’s on to the factory mags (did not ask him about 305’s and I am overseas at present so cant at this time).
This would make them almost the same diameter as the stock, but wider for the sand (and still within WA law i.e. still inside the ) and therefore the speedo would be out by only 0.5kph or so.
Wadda ya reckon ???
Wadda ya reckon ???
