When changing 4 speed to 5 speed ppl say change the top plate
What plate are they talking about I'm doing sd33t to l28
see pic. that is an sd33 (same as p40), l28 gearstick is further to the rear of the trans (suits the gearbox being further forward). the shaft for the transfer is slightly different on 4 and 5 speeds, but you can swap them over.
if you dont need the l28 one, ill purchase it. i need one.
the gearstick i imagine would be the same, but im guessing the transfer shaft is different again, but hopefully it can be swapped. take a pic if you get a chance.
Well Nerok if I get the bellhousing for xflow to sd33 box soon I will have stick from the l28 for ya
I have flywheel and pressure plate for xflow
Sd33 Na clutch plate
Ford clutch plate9.5 inch
Sd33na clutch plate 9.5 inch
Buy the bell housing , spigot , pivot ball
Use original thrust bearing and she all a goer
500 odd bucks for bh and bits better than 1200 for kit
