1 - 15 of 15 Posts
Does anyone know if you can adjust the clearview style tow mirror, manually. Most I have found come with a power plug, but I don't have power mirrors so wondering if this will still work or whether I would have to wire them up somehow to a switch. Do they just need power and ground?
I’m sure I found some full manual clear view copies on eBay last night.
Pass the Popcorn
Nissan Datsun Patrol
Th8s is what I have been trying to figure out myself for the last couple of months.
@turps I’d love to see a link to said manual copy (thinking Bettaview) cause I’ve been told they are available but can’t find them anywhere. I’ve even emailed suppliers and get a pretty blunt response from eBay sellers that “No sorry....We don’t stock that type” ect.
Pretty frustrating when your given varied info.
The smart thing to do might be to look at the Clearview web site. It shows that a set of electric mirrors for a GU Patrol is $745 and a set of manual ones for the GU are $695.
If you stumble upon them again, could you post the link. Not keen on spending 700 for a set of mirrors from clearview
How about these? I know they are electric but I'm pretty sure they can still be adjusted manually.
2016 CRD wagon
I would also guess you can adjust other electric ones manually.
I can definately adjust my electric clearview ones manually
Discussion Starter #8
Oh really that's good, the supplier I messaged about the electric ones said the electric part couldn't be adjusted manually. Might just give them a go, can on sell them if they don't work I guess. My Ute doesn't even have the extension arms for the mirrors atm so want to get something better
@JakeWild has something along these lines from memory, he might be able to offer some advice as well.
Super Moderator
I have seen the full manual versions Clear View. I'm not sure how they power up without looking into the workshop manual.
2016 CRD wagon
You cast an element of doubt in my head with this so I just double checked. I can definately move the electric mirror by hand. Of course only one of the mirrors are electric. The lower one is manually adjusted anyway (clearview brand).
Pass the Popcorn
I’m guessing your doing this by pushing on the glass itself to adjust it. I’ve had the thought of this myself as I used to do this with a falcon I once owned.
I suppose they could be fitted and used, with the option of wiring them up in the future as I’ve looked into the wiring diagrams and it can be done with the expensive second hand mirror switch.
Reactions: trev zd30
2016 CRD wagon
Discussion Starter #15
well i finally managed to buy a set of the ebay copy clearviews, electric ones and can confirm you can adjust them manually
1 - 15 of 15 Posts
