1 - 15 of 15 Posts
Currently lookingg to swap out my transfer case due to a stretched chain. I have a gu3 td42 but i can get a zd30 transfer case brand new pretty cheap just wondering if there are any differences? The part numbers are different from nissan the 4.2 one is 33100vb200 where as the zd one is 33100 vb010 any help would be appreciated thanks
could have different ratios would be my first guess ?
Yeah they look identical just wasnt sure and dont want to get all the way to putting it it and something be wrong
Give patrol apart a call. Always helpful over the phone and you should get an answer straight away without waiting for the right person on the forum to see your post.
When you do find out be sure to update the thread 👍
GQ Wagon TB42S
Out of curiosity, how did you diagnose the stretched chain?
Process of elimination really i originally thought it was the hubs as it was jumping in and out of 4wd when under load and sounded to come from the front right so i stripped the hubs down pulled axles out for a look and replaced my free wheeling hubs with some good refurbed ones i had around problem was still there then checked front tailshaft looked all good then after some research found others with the similar issue that replaced the t case and solved it so thats where im at. It has done alot of hard 4bying with 35s and decent power so it seems like a good answer
GU 2007 Cab Chassis Leafie, 6.5L Chev diesel, manual, slide on Tommy Camper on back
Hi @keats gu, I too am tracking down a bad noise, that occasionally happens when in 4wd, also from front right. So interested in your diagnosis. How would you describe what happens/sound heard as your Patrol jumps out of 4WD? is this the transfer case chain slipping on a driven cog.
Yeah thts what i beleive it is monkey mine does it mainly on sand for some reason itll drive along then make a decent clunk/bang and lose drive to the front then i just stop and go again till it does it again sounds pretty cruel some times. Just spoke with patrolapart and according to them all the transfer cases are the same the only dofferences are some switches depending on model man/auto etc
Yep, sounda familiar. in heavy sand only in 4wd, i get a big CLANG ,metallic bang, like a sudden release under tension. not all the time, but when car is working hard through boggy stuff...
Gu TD42 series 3 wgn
Mine exactly does the same on the sand. Sounds and feels horrible. Let me know if it works. Been chasing this gramlinfor ages.
Maybe that helps a little
33100VB200 NISSAN Safari
SAFARI10.199709.1999Y61JapanWRGY61WAGONTD42TRXMT
SAFARI12.200912.2016Y61General/Asia (LHD)WAGONTD42STDMT
SAFARI09.199911.2002Y61JapanVRGY61VANTD42TGRLMT
SAFARI12.200912.2012Y61General/Asia (RHD)WAGONTD42GRMT
SAFARI10.199712.2009Y61General/Asia (LHD)WAGONTD42ADMT
SAFARI04.199911.2002Y61Australia (RHD)WAGONTD42TSTDMT
SAFARI10.199712.2009Y61General/Asia (RHD)WAGONTD42STDMT
SAFARI10.199712.2009Y61General/Asia (RHD)WAGONTD42ADMT
SAFARI10.199709.2001Y61General/Asia (LHD)WAGONTD42ADMT
SAFARI12.2009Y61General/Asia (LHD)WAGONTD42ADMT
SAFARI11.200201.2007Y61Australia (RHD)WAGONTD42TISTDMT
SAFARI12.2009Y61General/Asia (LHD)WAGONTD42GRMT
SAFARI12.201212.2016Y61General/Asia (RHD)WAGONTD42GRXMT
SAFARI12.200912.2016Y61General/Asia (RHD)WAGONTD42ADMT
SAFARI10.199712.2009Y61General/Asia (RHD)WAGONTD42GRMT
SAFARI10.199712.2009Y61General/Asia (LHD)WAGONTD42STDMT
SAFARI12.200912.2016Y61General/Asia (LHD)WAGONTD42ADMT
SAFARI12.2009Y61General/Asia (RHD)WAGONTD42STDMT
SAFARI12.2012Y61General/Asia (RHD)WAGONTD42GRXMT
SAFARI11.200201.2007Y61Australia (RHD)WAGONTD42TIADMT
SAFARI10.199709.1999Y61JapanWRGY61WAGONTD42TGRMT
SAFARI12.2009Y61General/Asia (LHD)WAGONTD42STDMT
SAFARI12.200912.2016Y61General/Asia (LHD)WAGONTD42GRMT
SAFARI12.2009Y61General/Asia (RHD)WAGONTD42ADMT
SAFARI12.200912.2016Y61General/Asia (RHD)WAGONTD42STDMT
SAFARI10.199709.1999Y61JapanWRGY61WAGONTD42TGRLMT
SAFARI04.199911.2002Y61Australia (RHD)WAGONTD42TADMT
SAFARI10.199702.2000Y61Australia (RHD)WAGONTD42STDMT
SAFARI10.199712.2009Y61General/Asia (LHD)WAGONTD42GRMT
33100VB200 NISSAN Pick UP (Ute)
SAFARI PICK UP02.199912.2002TY61Australia (RHD)PICKUPTD42STDMT
SAFARI PICK UP12.200208.2007TY61Australia (RHD)PICKUPTD42TISTDMT
SAFARI PICK UP02.199912.2002TY61Australia (RHD)PICKUPTD42TSTDMT
SAFARI PICK UP12.200208.2007TY61Australia (RHD)PICKUPTD42TIADMT
SAFARI PICK UP09.199912.2012TY61General/Asia (LHD)PICKUPTD42STDMT
SAFARI PICK UP02.199912.2002TY61Australia (RHD)PICKUPTD42TADMT
SAFARI PICK UP12.200212.2012TY61Australia (RHD)PICKUPTD42TISTDMT
SAFARI PICK UP09.199912.2012TY61General/Asia (RHD)PICKUPTD42STDMT
33100VB010 NISSAN Patrol
02.200010.2002Y61Europe (RHD)HARDTOPZD30DDTIADMT
PATROL02.200012.2008Y61Europe (RHD)WAGONZD30DDTIGRMT
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIGRATSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
PATROL02.200003.2010Y61Europe (LHD)HARDTOPZD30DDTIADMTSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIGRMTSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
PATROL02.200010.2002Y61Europe (RHD)WAGONZD30DDTIADAT
PATROL02.200003.2010Y61Europe (LHD)HARDTOPZD30DDTIGRATSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
PATROL02.200012.2008Y61Europe (RHD)WAGONZD30DDTIGRAT
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIGRXMTSEAT TYPE:EUROPE D GROUP 5P
PATROL02.200010.2002Y61Europe (LHD)WAGONZD30DDTIADATSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIGRXMTSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
PATROL02.200012.2008Y61Europe (RHD)WAGONZD30DDTIADMT
PATROL02.200012.2008Y61Europe (RHD)WAGONZD30DDTIGRXAT
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIGRXATSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIGRATSEAT TYPE:EUROPE D GROUP 5P
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIADMTSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIGRMTSEAT TYPE:EUROPE D GROUP 5P
PATROL02.200003.2010Y61Europe (LHD)WAGONZD30DDTIGRXATSEAT TYPE:EUROPE D GROUP 5P
PATROL02.200012.2008Y61Europe (RHD)HARDTOPZD30DDTIGRMT
PATROL02.200012.2008Y61Europe (RHD)HARDTOPZD30DDTIGRAT
PATROL02.200003.2010Y61Europe (LHD)HARDTOPZD30DDTIGRMTSEAT TYPE:CENTRAL & SOUTH EUROPE 5P
33100VB010 NISSAN Safari
12.2012Y61General/Asia (RHD)WAGONZD30DDTISTDMTAREA:GENERAL AREA
SAFARI03.200012.2009Y61General/Asia (LHD)HARDTOPZD30DDTIGRATAREA:GENERAL AREA; SEAT TYPE:2ND FWD FACING(9710-0912)
SAFARI12.2009Y61Australia (RHD)WAGONZD30DDTIADATSEAT TYPE:7 SEATER TYPE
SAFARI12.2012Y61General/Asia (RHD)WAGONZD30DDTIADATAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI12.200912.2012Y61General/Asia (LHD)WAGONZD30DDTIGRMTAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.200912.2012Y61General/Asia (LHD)WAGONZD30DDTIGRATAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.2009Y61General/Asia (RHD)WAGONZD30DDTIADMTAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI12.2012Y61General/Asia (RHD)WAGONZD30DDTISTDMTAREA:GENERAL AREA; SEAT TYPE:3RDSIDE 10PASSENGER(0912-
SAFARI12.2009Y61General/Asia (RHD)WAGONZD30DDTIADMTAREA:SAF; SEAT TYPE:2ND FWD 5PASSENGER(0912-)
SAFARI12.2009Y61Australia (RHD)WAGONZD30DDTIGRMTSEAT TYPE:7 SEATER TYPE
SAFARI12.2009Y61Australia (RHD)WAGONZD30DDTISTDATSEAT TYPE:5 SEATER TYPE
SAFARI12.2009Y61General/Asia (LHD)HARDTOPZD30DDTIGRMTAREA:GENERAL AREA; SEAT TYPE:2ND FWD FACING(9710-0912)
SAFARI03.200009.2001Y61General/Asia (LHD)WAGONTB45EGRATAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI03.200012.2009Y61General/Asia (RHD)HARDTOPZD30DDTIGRATAREA:GENERAL AREA
SAFARI03.200012.2009Y61General/Asia (RHD)HARDTOPZD30DDTIGRATAREA:GENERAL AREA; SEAT TYPE:2ND FWD FACING(9710-0912)
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTIADMTAREA:GENERAL AREA; SEAT TYPE:3RD SIDE FACING(9710-0912
SAFARI10.199709.1999Y61JapanWAGONTD42TRXAT
SAFARI11.200212.2009Y61Australia (RHD)WAGONZD30DDTISTDATSEAT TYPE:5 SEATER TYPE
SAFARI08.199709.2001Y61General/Asia (LHD)WAGONTB45EGRXATAREA:MIDDLE EAST AREA; SEAT TYPE:3RD SIDE FACING(9710-0912
SAFARI10.199709.2001Y61General/Asia (RHD)WAGONTB45EGRXATAREA:GENERAL AREA
SAFARI10.199709.2001Y61General/Asia (LHD)WAGONTB45EGRXATAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.2009Y61General/Asia (LHD)WAGONZD30DDTIADMTAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI12.2009Y61Australia (RHD)WAGONZD30DDTISTDMTSEAT TYPE:5 SEATER TYPE
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTISTDMTAREA:GENERAL AREA
SAFARI10.199709.1999Y61JapanWAGONTB45ERXAT
SAFARI08.199709.2001Y61General/Asia (LHD)WAGONTB45EADATAREA:MIDDLE EAST AREA; SEAT TYPE:3RD SIDE FACING(9710-0912
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTIADATAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.200912.2012Y61General/Asia (LHD)WAGONZD30DDTIGRATAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI12.2009Y61General/Asia (RHD)WAGONZD30DDTIGRXATAREA:GENERAL AREA
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTIGRXMTAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTISTDMTAREA:GENERAL AREA; SEAT TYPE:3RD SIDE FACING(9710-0912
SAFARI12.2009Y61General/Asia (RHD)WAGONZD30DDTIGRXMTAREA:GENERAL AREA
SAFARI12.2009Y61General/Asia (LHD)WAGONZD30DDTIADMTAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI10.199709.2001Y61Australia (RHD)WAGONTB45EGRATSEAT TYPE:7 SEATER TYPE
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTIADATAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI12.2009Y61General/Asia (RHD)WAGONZD30DDTIGRXATAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI12.2012Y61General/Asia (RHD)WAGONZD30DDTIADMTAREA:SAF; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI03.200012.2009Y61General/Asia (RHD)WAGONZD30DDTIGRXATAREA:GENERAL AREA
SAFARI09.199911.2002Y61JapanVANTD42TGRAT
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTIADMTAREA:GENERAL AREA; SEAT TYPE:3RDSIDE 10PASSENGER(0912-
SAFARI12.200912.2012Y61General/Asia (LHD)WAGONZD30DDTIGRMTAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI10.199709.1999Y61JapanWAGONTD42TGRAT
SAFARI10.199711.2002Y61JapanWAGONTB45EGRAT
SAFARI08.199709.2001Y61General/Asia (LHD)WAGONTB45EGRXATAREA:MIDDLE EAST AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTIGRXATAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTIGRXMTAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI09.199911.2002Y61JapanVANTD42TGRLAT
SAFARI03.200012.2009Y61General/Asia (RHD)WAGONZD30DDTIGRXATAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI10.199711.2002Y61JapanWAGONTB45EGRLAT
SAFARI08.199709.2001Y61General/Asia (LHD)WAGONTB45EADATAREA:MIDDLE EAST AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.2009Y61Australia (RHD)WAGONZD30DDTIADMTSEAT TYPE:7 SEATER TYPE
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTISTDMTAREA:GENERAL AREA; SEAT TYPE:3RDSIDE 6PASSENGER(0912-)
SAFARI12.2009Y61Australia (RHD)WAGONZD30DDTIGRATSEAT TYPE:7 SEATER TYPE
SAFARI10.199709.2001Y61General/Asia (RHD)WAGONTB45EGRXATAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.2009Y61General/Asia (LHD)HARDTOPZD30DDTIADMTAREA:GENERAL AREA; SEAT TYPE:2ND FWD FACING(9710-0912)
SAFARI09.199911.2002Y61JapanHARD TOPZD30DDTIS/SPAT
SAFARI10.199709.2001Y61Australia (RHD)WAGONTB45EADATSEAT TYPE:7 SEATER TYPE
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTIGRXATAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI12.2009Y61General/Asia (RHD)WAGONZD30DDTIGRXMTAREA:GENERAL AREA; SEAT TYPE:3RD FWD 7PASSENGER(0912-)
SAFARI10.199704.1999Y61Australia (RHD)WAGONTB45EDXATSEAT TYPE:7 SEATER TYPE
SAFARI12.2012Y61General/Asia (LHD)WAGONZD30DDTISTDMTAREA:GENERAL AREA; SEAT TYPE:3RDSIDE 10PASSENGER(0912-
SAFARI03.200012.2009Y61General/Asia (LHD)WAGONZD30DDTIGRATAREA:GENERAL AREA; SEAT TYPE:3RD FWD FACING(9710-0912)
SAFARI02.200012.2009Y61Australia (RHD)WAGONZD30DDTIADATSEAT TYPE:7 SEATER TYPE
SAFARI12.2009Y61General/Asia (LHD)HARDTOPZD30DDTIGRMTAREA:GENERAL AREA; SEAT TYPE:2ND FWD 5PASSENGER(0912-)
SAFARI10.199709.1999Y61JapanWAGONTD42TGRLAT
33100VB010 NISSAN Safari Pick UP (Ute)
08.200712.2012TY61Australia (RHD)PICKUPZD30DDTIADMTSUSPENSION:COIL
SAFARI PICK UP12.2012TY61Australia (RHD)PICKUPZD30DDTIADMTSUSPENSION:COIL
SAFARI PICK UP12.2012TY61General/Asia (RHD)PICKUPZD30DDTIADMTSUSPENSION:LEAF; AREA:GENERAL AREA
SAFARI PICK UP12.2012TY61General/Asia (RHD)PICKUPZD30DDTISTDMTSUSPENSION:LEAF; AREA:SOUTH AFRICA
SAFARI PICK UP08.200712.2012TY61Australia (RHD)PICKUPZD30DDTISTDMTSUSPENSION:COIL
SAFARI PICK UP08.200712.2012TY61Australia (RHD)PICKUPZD30DDTISTDMTSUSPENSION:LEAF
SAFARI PICK UP12.2012TY61General/Asia (LHD)PICKUPZD30DDTISTDMTAREA:GENERAL; SUSPENSION:LEAF
SAFARI PICK UP12.2012TY61General/Asia (LHD)PICKUPZD30DDTIADMTAREA:GENERAL; SUSPENSION:LEAF
SAFARI PICK UP12.2012TY61General/Asia (RHD)PICKUPZD30DDTISTDMTSUSPENSION:LEAF; AREA:GENERAL AREA
Cheers Thomas
GQ Wagon TB42S
Wow, thats really interesting info! Where were you able to get this from? I'm guessing that it would be an absolute treasure-trove for those seeking this type of detail.
Thanks for sharing.
what i can tell you is a 2.8 transfer case will work but there is like a spill tray under the input shaft seal which you have to chop off to make fit.
the 3.0l and 4.2l transfer should be identical as its the same gearbox in front of it.
Hi @keats gu - when you get the TC installed and tested, can you drop back here and let us know if it solved your clunk/bang in 4WD problem? Thanks.
BTW do you intend overhauling or even opening up the current TC with suspect stretched chain in it?
If you do, that would also be helpful, to get a few pics of a stretched chain or what else you found (damaged teeth) etc.
Thanks
1 - 15 of 15 Posts
