1 - 5 of 5 Posts
when i am driving with it in four low it pops out but if i hold it there it dosent have any problems with it. I dont have a body lift but i do have leaf sag which i think is the problem. any help is good
Hi,
I've had this in an other vehicle of mine. The little springs that hold the gear shafts in place with a locking ball could be broken or worn. Due to fatigue, the tension of the spring isn't sufficient anymore to hold the locking ball in the slot of the shaft. Therefore if you just hold the lever manually in place, it doesn't pop out anymore.
Normally, if this is the cause, then there should be less resistance to put in low gear.
1986 SD33T SWB
Worn or split engine and transmission mounts can also cause it. If that is the issue the shifter boot will sometimes pop out of place too.
It won't be sagging leaf springs.
Ive had this problem before, the transfer shifter boot was on the wrong way and was pushing on the stick when in low 4.
rotated the boot 180 degrees and problem fixed.
thank you that was the problem
1 - 5 of 5 Posts
