1 - 14 of 14 Posts
It will also trap water and mud and crud. Same reason we don't install muffler wrap on a 4wd. Lift the rear of your bonnet, install a bonnet scoop.... or 2.
I looked into this a while ago. I came to the conclusion it would be better to make up a shield from steel ect as this will not have such a drastic effect on cool down times.
Also it is def not a good idea unless you have a water cooled turbo/turbo timer. As it could cause the oil to cook after the engine shuts down and oil stops circulating.
Thanks, I didn't think about mud!
Trying to find some heat resistant shielding to wall off the aux battery from the turbo/exhaust.
I will check out the raising of the rear of the hood, first thought was a bonnet vent but this sounds easier and cheaper to start with.
Plenty of plastic out there.
Do some research, find some plastic and have it bent to shape.
Most passenger car batteries are in a plastic 'box' to protect them from heat - why bother with steel when it will just soak up the heat anyway.
Banned
Fab up an alloy heat shield if you just want to protect the battery.
Otherwise some $$$ ceramic coating on the dump pipe & rear housing will lower underbonnet temps...
BLACK BETTY
Have a turbo blanket on my top mount turbo. Was concerned about the heat from turbo affecting my 2nd battery. Seem to work well.
I am not to concerned about mud etc up that high. If I am that deep in the [email protected]#t then having mud around my turbo is the least of my worries.
As for the cool down time just set your turbo timer a little longer if you are that concerned.
What iv use in the past is the side cut out of a "square-ish" 20lt drum the ones
use for truck wash and stuff.
Just cut it out with a bend to suit the backside of the battery closest to the turbo.
stick on some kind of heat tape/cover and mount it.
We also used to put a 2.5/3" hose to this on the taxis we used to
look after, as they run 24/7 they never used to get a good run from
battreis because of heat build up.
Cheers Ian.
Is it better to raise the bonnet or fit a scoop?
I was under the impression that the "factory" design is to direct
air under the vehical.
Cheers Ian.
I have a turbo beanie on my water/oil low mount turbo as well as a alloy heat shield for the exhaust manifold which i think was a thermo-tec product.
Definatley noticed a difference in engine bay temps, things are not perishing from heat but then i don't go looking for mud to bogg it in so i'm unaware of the drawbacks in that department.
gday,
ive been running a beanie for quite a while and had no dramas, but i always let it cool down after a hard run. After a big run with exhaust temps still high you can put your hand on the cover without burning yourself. Something to consider if your running a high mount and air to air cooler. As far as mud goes it washes off quite easily. my 2c worth
1 - 14 of 14 Posts
