I was wondering where in Melbourne or Geelong can I get a after market dump pipe & price for my GUIV 4.2TD.
the dump pipe is the elbow that come out of the back of the turbo. one end of the dump pipe bolts to the back of the turbo, and one end goes onto your exhaust pipe. the standard dump pipe has an inside diameter of 1.7", the aftermarket ones range from 2.5-3" IDmickyd213 said:I'm what you would call... uneducated in the ways of turbos. What is a dump pipe used for and what do they look like?
did you try to up the fuel pressure a tiny bit ,but i am surprised your boost dropped maybe there is something else possibly blocking the exaustAshleyhj74 said:Well, we fitted the dump pipe to the patrol. Gotta say, i'm disappointed. Before the pipe was on, in 3rd it'd crack 10psi at 2000rpm (just), now its barely getting 8psi. It pulls worse down low in the rev range, and i'm basically regretting spending the money to get one so far. Doesnt go better up in the rev range either. Changing to thermo fans from the standard clutch fan gave me a much more noticeable result than this bloody thing.
Well you do get what you pay for!Ashleyhj74 said:Well, we fitted the dump pipe to the patrol. Gotta say, i'm disappointed. Before the pipe was on, in 3rd it'd crack 10psi at 2000rpm (just), now its barely getting 8psi. It pulls worse down low in the rev range, and i'm basically regretting spending the money to get one so far. Doesnt go better up in the rev range either. Changing to thermo fans from the standard clutch fan gave me a much more noticeable result than this bloody thing.
well only if it was legal to have your screamer pipe go into the atmosphere and not back into the exhaust, be better if you had a external wastegate as well, then you will be able to control your boost a lot better, pretty fun on a petrol but not so much on a dieselGU42TD said:for even more performance you could get one custom made like this.
the smaller pipe is for the wastgate gases, this works better as ther is no turbulence inside the dump pipe when the wastegate and main exhaust gases meet.
if you really want to turn some heads, instead of making the smaller pipe meet back into the main pipe, just let the wastegate gases release into the atmosphere, this is called a screamer. like in this photo, the big pipe is for the main gases, and the smaller pipe is the screamer (they dont have to be two pieces by the way, this was all i could find)
that would be the safest option to have it set up on a dyno by a mechanicAshleyhj74 said:I paid for a cast 3" dump pipe, from Denco in NSW. It was identical to the cast 3" dump pipe MTQ wanted to sell me for $275, and identical to the other one some dyno place out nth melbourne wanted to sell me for $295. Wild guess here, they came from the same casting. But please, if you think i got ripped off and want to go pay the extra $100. I wont stop you mate. As for upping the fuel pressure a bit, how do i know what its currently set to? How do i know its right now? How do i know what i'm setting it too? I'd rather not take the chance i dont think
. I guess i'll just live with what i've got untill i have the spare cash to get the pump setup to the correct settings at the local diesel injection place.
