1 - 2 of 2 Posts
nissan patrol gu
Hey guys im new to all this stuff but i have just bought a 2000 model gu patrol cab chassis td42 ive bought a replacement turbo to replace the ebay set up that was already on it .i have bought a turbo that is the same as the original ht18 just a diffrent brand and it seems as if its set up for a low mount ,but the guy i bought it from told me it can also be set up to a high mount to suit the manifold i have is this possible? any help or advice use guys could give would be great thank you.
The most important thing is to have the centre cartridge orientated the correct way, oil in the top return at the bottom. You do this by loosening the bolts that hold the turbine and compressor housings and spinning them to the position they need to be.
1 - 2 of 2 Posts
