Hi all, as my HT18 is water cooled and when the new turbo goes in Matt said dont need to use the water cooling for it, could I use the two coolant pipes that usually go to the turbo for the twine hot water setup? would there be enough flow to heat the water?
cheers DD.
Nissan patrol gq
It could be done that way however you lose the ability to control the water temp via the heater control in the cab.
You could put a ball valve on it to restrict the coolant flow to gain the desired temperature though
Thanks for your reply, may need to investigate more.
Cheers DD.
