Hi all, I have made this thread / post for those who don’t know or just want a rought guide on getting rear body bolts out on GU Patrol, if snapped or just F*#@ED,
REALLY HOPE THIS HELPS SOME AND OR GIVES SOME WHAT OF A GUIDE CAUSE THERES NOTHING REALLY OUT THERE WHAT I COULD FIND ABOUT THIS
--Tools used:
-Dremial with steel / grinding disc on dremial.
-Vice Grips to grab top of bolt and undo coming up (see Photos ATTACHED)
--Location Of Where To Cut
-Passenger side is easy (seen in attached photos you can have a rough guess where to cut sorry I don’t have measurement’s
-Drivers side you will have to remove the inside plastics / panel couple screws/bolts/clips and comes right off and remove the jack holder
My Cutting is a bit of butcher I was just using eye cromiter to have a rough area where to cut and then went to town, Have / Did also purchase Primer and resprayed and neaten up cuts and covered with water proof cover sticker thing from bunnings, reason didnt reweld closed is due to if need be in future, easy access to rear body bolt,
Passanger Side--
Extra Cuts-
REMOVED BODY SNAPPED BOLT-
DRIVER SIDE CUT N REMOV BOLT-
--Tools used:
Passanger Side--
Extra Cuts-
