Greetings, I bought some tires "kumho AT 32x11.50 R15", but would like to help me telling me what is the correct air pressure for tires, originally a "TROLL" 265x70R16 and comes with the manual states that the front wheels must be 29psi and 36psi rear, what should be the correct pressure for my new tires.
Saludos, compré unas llantas "kumho 32x11.50 R15 AT", pero quisiera que me ayuden indicándome cuál es la presión de aire correcta para las llantas, originalmente el "TROLL" viene con 265x70R16 y en el manual indica que las llantas delanteras deben tener 29psi y las posteriores 36psi, cuál debería ser la presión correcta para mis nuevas llantas.
chalouio | Just another WordPress.com site
Discussion Starter · #2 ·
I forgot to mention, the tires are all terrain KUMHO 825
olvidé mencionarlo, las llantas son KUMHO 825 todo terreno.
nissan patrol swb gq
Mate, I would try 32psi all round and see how that feels. I would say anywhere between 32 and 35psi would be fine.
maximum tire load: 1150kg
psi max cold: 50psi
Troll weight: 3020kg
Troll weight / 4 wheels: 7550kg per wheel
weight per wheel / tire weight limit
755kg/1150kg: 0.66 (multiplier)
0.66 x 50 psi (maximum tire psi): 32.83psi
more 4psi result: 37psi
