G'day guys,
Am leaning towards getting a UFI Td05 18g turbo upgrade (low mount). My main question for those using one or that know, what are options for an exhaust ? I'm running a TD4.2 in a GU IV with a 3" exhaust already.
What I gather is the bolt up is different to that of the HT18, and I see the turbo comes with its own dump. How ever i can't see it attaching direct to my exhaust as my current dump is a few inches longer. Is there a set exhaust I can get to fit on? Or I will need to cut mine and join it somehow ?
Mine bolted straight up no worries. Best talk to UFI
I called them and the bloke was so unhappy to speak too me and barely said a word like I should know the stuff I was asking. So I got bugger all from him
Any exhaust that bolts to a factory dump pipe, or a factory replacement type dump pipe will bolt to our dump pipe.
That is the same answer I give possibly 5-10 times a day.
Manta exhausts will fit. If not, $150-200 at a exhaust shop for a simple reconnect typically.
No we do not use the HT18 style turbine housing, it still suffers from many of the issues we see when fitted to the HT18.
thats bit crappy. i must admitt, ive called them a few times and unless speaking to Matt himself, got a similar result. Matt is normally pretty helpful.
mines a few years old and thing may have changed but the dump was just standard triangular 3 bolt flange.
as the others said, if its different, exhaust shop will change it pretty quickly and cheaply.
