Anyone running the new ultra flexy coils from suspension stuff ?. If so hows the ride, wheel travel and final ride height once settled ?. I recieved mine friday but wont be putting them in until I get a set of SRC shocks in a few weeks. Shane has a bit of a write up on the outer limits 4x4 forum I have included here, but I was hoping someone here might have tested them in a patrol GU ute and has any info.
RE:SUSPENSION STUFF / OUTER LIMITS 4X4
We have changed our flexy coils to ultra flexy coils.
Soon we will have them in normal duty and extra heavy duty.
Normal duty are designed for loads up to 150kg and the extra heavy duty coils 21mm wire will be for those with more weight. Having extra heavy coils without extra load will give a rough ride though.
Our Ultra flexy coils will flex about 2 inches more then our regular flexy coils.
You could run EFS Extremes with our normal 3" flexy coils, so with out ultra flexy coils you can easily run longer shocks then the EFS Extremes.
I am re-doing all heights so we are as close as possible to a 75mm lift for our 3" lifts so not higher then a normal coil, maybe a bit lower, and you can purchase them in half inch intervals meaning you can get a 3.5" also.
Our Ultra flexy coils will have a 5 year warranty and unless you have black ones, you don't have the Ultra Flexy Coils. (Unless you were part of the testing)
With the testing so far and customer feedback, our normal duty Ultra flexy coils are very comfortable without much body roll at all.
You will not find any feedback on this forum about our Ultra flexy coils because not many people have them yet.
