I have noticed some strange wear on my front tryes.
The wear is in one section on both front tyres, its is a bit hard to see in the pics but both edges of the tread blocks are being rounded off.
The tyres are Goodyear Duratracs 265/75R16s and have done about 3000 Ks since new and where fitted to new 16x8 dynamic rims.
I put a new drag link on and got a wheel alignment the day after the tyres where fitted.
I have not noticed any strange vibrations and I have not locked up the brakes to cause a flat spot.
Taking the truck back to the tyre shop tomorrow to see if they can help
So any ideas?
Discussion Starter · #2 ·
I got the truck back from the tyre shop and they have no idea either.
Anyway I thought I would have a look at the swivel hub bearings, the passenger side was not loose but I took the shims out just to tighten it up a bit.
The drivers side was quite notchy and the grease has been washed out as a result of the inner axle seal leaking.
So I washed out the bearings, repacked them, removed the shims and put it all back to gether. It turns a lot smoother now, lets see how that goes.
I have ordered an overhaul kit which I will put in when I have a spare day.
That's odd. I've never seen that before.
I have gone through a set of Duratrac's. On my second set and have them on two vehicles. One is at 18,000 the other at 12,000 and all are wearing dead even and nicely. First set went to 72,000 km's.
