1 - 3 of 3 Posts
I have 2 questions for all of you running gt2860rs turbos. On low mount manifolds.
1. Have you all had to reverse the bracket for the boost actuator [take it off and turn it 180 geg.] and in doing so spaces the actuator further away. Is the standard actuator arm long enough. I want to run low boost till I get it set up on .dyno
2. There is hardly any space between the oil feed and the flange not enough for the fittings I have. What have you used.
I would appreciate any imput on these matters as I need to sort it out asap as I have booked it in to get exhaust made up next week but obviously cant with no oil feed and am paronoid about the tightness of the actuator.
Cheers Chris.
Discussion Starter · #2 ·
Answered question 2 myself was reading Installation guide incorrectly. It says turbine shaft should be within 10deg of horizontal. Which I mistook for oil feed/drain which can be at 35deg.
Hopefully should solve my problem.
I have a DTS low mount manifold
I have a GT2871R and i had to turn my actuator bracket around and drill 2 new holes 90 degrees from the orginal holes to bolt the actuator to the bracket and got a longer actuator rod from MTQ
I have a boost controller to adjust boost
Hope this helps
1 - 3 of 3 Posts
