1 - 2 of 2 Posts
nissangupatrol
I had to take the tail shaft out of the toner to replace the rear main seal. I have now put it back in however I have vibes around 70....what should I be looking at??
some tail shafts have weights on them they may have fallen off.
did you mark it when you pulled it out ie bolt hole on tail shaft to bolt hole on transfer case as you may have it out a hole or two and this will cause vibration
1 - 2 of 2 Posts
