My wife just put on some MTZ 284/75/16 and MT rims on the '98 ST ute. They look great but rub a little on full lock (on the mudflap bracket). What is the best option. Coils spacers or cab blocks? Will post a pic soon.
Cheers.
Cheers.
Yes but its also over 12 years old so you springs will have definitely sagged. Cheapest and easiest way would be some coil spacers, but I personally would put in some new springs and shocks, it will drive a lot nicer too.It has only just done 100k so suspension should still be ok.
Mate, you might have been able to avoid the bod(ge)y lift by using radius arm spacers. They push the axle forwards specifically for clearance issues you mentioned.Well last night I put in some 40mm cab spacers and longer high tensile bolts. Took two hours by myself so wasn't that hard. And the wheels no longer rub. So far all I have had to do is remover the bottom radiator shroud but will check the levers out tonight. So far so good.
Camping by the Snowy riverThat is good to know. At least I can drive it now. Will look into the arm thingies. And remove the blocks if needed. Where were you a few weeks ago?
GT
No problem mate.And I have ordered the radius arm spacer kit.
Thankx for the headsup.
