Hi there, I have been meaning to join you guys for ages and my GU has finally twisted my arm into doing it!
My GU 4.8 (12/2001) is idling at 1500 rpm in neutral, 1200 in Drive, and ocassionally revs up to 2700 rpm and back down to 1500, back up to 2700 etc etc. It does this sitting in neutral,idling. It is also chewing through 40-50 litres per 100k's on LPG and Premium ULP.
I checked the timing and it is retarded at idle (1500rpm) and when I start to advance it, it seems that the computer takes over and keeps on advancing it until the knock sensors cause it to be retarded, then the computer advances again, and so on. This coincides with the revs going up and down. The most I can advance it is to 6deg retarded before it starts playing up.
I have just got Datascan II, and am trying to work it out. All I've tried so far is advancing the timing and it did the same as turning the cam sensor.
I have recently changed the MAF sensor, o2 sensors, coolant temp sensor, had the injectors done, throttle body clean, checked CAT, checked for vacuum leaks.
It's been to two mechanics but I have come to the conclusion that I am going to have to work it out myself. Any suggestions will be greatly appreciated.
Please help??? Thanks in advance -Troy :headwall:
I should have kept my GQ with the 454 in it (legally registered in QLD!), just the kids were scared of it and would only go in it with helmets or ear muffs on!
