1 - 14 of 14 Posts
I had noticed the fan seemed noisier than normal lately.
I checked it and it appears to have seized up solid.
Can the hub be drained and refilled or does it have to be replaced?
Its a TD42 engine.
Cheers,
HG
nissan patrol gq
Yeah most desel are serviceable.remove fan from it,if there still more bolts there, take them out and take apart. Clean out and add two tubes off fluid from Toyota.diy on it here somewhere.search.
As benos said if bearing it's a throwaway.
I replaced my entire viscous hub setup with dual switchable fans out of an el falcon - fit perfectly and stays much cooler as a bonus :) only cost about $250 all up as well
where did you out the thermo switch, thinking of doing this so I have cooling after the engine is turned off, mine gets really hot after shutdown.
Super cheap sell a thermo switch for around 60 bucks (without relay) fully adjustable, I mounted it near the pre filter on the lhs of the engine bay as the probe wire was too short to cabin mount it, I have hooked it up by a 3 way switch so that I can have the fans on a bypass, off or on (off so that I can do deep water crossings), I also wired each fan has it's own relay and fuse. I have it set at around 190 degrees F and it cuts out after a minute or so with a temp of around 180. They don't however fit with the existing engine fan still in place so they are a replacement not an addition
· Banned
Put it on the other side of the radiator if there is room there.
· Previously known as twodiffs
1991 GQ Safari.
Would be keen to see some pics of that mate...can you put some up??
1 - 14 of 14 Posts
