MAF VOLTAGE MATTERS !
I will never ever repeat enough how important MAF voltage is.
Two Italians recently came to me to buy Magic Boxes. One with limp modes, the other with apparently no problem. He bought his 2001 Di two years ago, second hand.
This is the short record the second guy sent me, which I replayed at home :
Not a genuine MAF ! even at 18psi (1.25 bar), the MAF voltage does not exceed 3.2 volts !
No need to say his Patrol was very "laggy" and had no power. The fueling decided by the ECU, and instructed to the IP, depends upon TPS and MAF voltage !!
He said he had a chinese spare he bought a while ago but never tried.
He did, and this is the result : in his own words, his Patrol turn into a "Missile". I guess his Italian word would have translated by "rocket" in french :
This time, with the chinese MAF, the MAF voltage was much much higher (and even far too high, as it saturated at 4.5V quite often). The ECU believes there is plenty of air, and direct the IP to inject a lot of fuel (reduced AFR as a result). MB prevents limp from occuring. So his Patrol was transformed, and run like hell.
My advise to him was nevertheless to get a Genuine MAF even if we can correct his MAFs voltages with MB (although the "saturating chinese MAF" makes the exercise almost impossible : MB cannot "re-build" a correct MAF value from all values which have saturated at 4.5V ).
This sequence also shows a "hidden feature" of MB which is to get the ECU to increase fueling by "tweaking" the MAF voltage and increasing it a bit with MB. But use this feature carefully, and only if you don't have a remap already.
In any case, starting your turbo tune with a good Genuine MAF is by far the best.
