Works beautifully.
I love electronics and software when they assist in getting the most out of mechanical components.
Here is what I now get when I unplug my MAF and switch Dip-switch 4 to 'ON'. ( Don't do that on your MB as you don't have the new firmware. But you can try to unplug your MAF and check how your Patrol drives with no MAF, with the current firmware).
MB reads something like the TPS value out of MAF_in "in the air". So the ECU will not notice. No MIL code, better than what the ECU does (security mode), but since the TPS voltage is on average less than what you can get out of a working MAF when your turbo map is well tuned, I can't say it is a perfect "work-around" for when you MAF is down. But it "sort of works". Just bear in mind that the more you press the throttle, the more MB ( and your ECU) will read a higher "MAF" voltage. However, when idling, the voltage will remain low ( 0.5V instead of 1.6V to 2.0V). Better than nothing. But far from perfect.
I have now tested a true "MAF failure mode" function. My Patrol almost drive the same, as the MB "estimate" of the MAF voltage is very close to what a working MAF would deliver.
With an unplugged MAF, below is (dark blue - bottom graph) the MAF_in data ( almost identical to TPS - beware of the different Y scales), and in light blue the "MB-estimated MAF' provided to my ECU. I did not think it would be that good, and almost unoticeable when I drive.
Of course this suppose that your turbo map is well tuned. And MB continues to take care of any limp since I have no remap, hence the MAF voltage which is above the limp thresholds when pushing gears.
