1 - 5 of 5 Posts
Hey guys
For those who have W2A coolers with a tank to increase liquid capacity. Where did you mount the tank and where in the system did you connect it up?
I have a small tank in line, It is also the fill point, It holds about 3.5lt.
You can see the inlet at the top the outlet is on the front side at the bottom left and flows straight to the top of a double pass PWR rad, then to the pump the back to the core. After towing about 1.2t on 35'' up a range and pyro getting to 550degC the cooler is still cold.
nissan patrol gu11
I'm just using a small one , mainly for filling, but I have a large cooler and the system all up holds nearly 10 liters.
1 - 5 of 5 Posts
