Has anyone changed an 12v electric Warn 9000 to a Hydraulic winch?
Just looking at mine while giving it the once over after the Simpson trip and was just thinking it cant be that hard.
cheers DD.
Weekend Warrior
Nissan patrol
A second power steering pump and a hydraulic motor out of a log splitter or something could be the go, you may need a pressure relief so the motor doesnt break the winches gearbox, or not.
Getting a control block/manifold to do the changeover reliably without any slippage could be the expensive part. ?
GHMBC #3
nissan patrol gq lwb,3"lift.
when i worked on trawlers in the 90's we had rope hoists/winches that were hydro. they were 10000lb with what was called sharlin (sp) motors about the size of a 6hp 12v winch motor.when they were overloaded the internal bylass released the pressure but held the weight.often thought about this set up as i remember them having a keyed shaft like some winches
