1 - 20 of 23 Posts
Hi guys I’m trying to install a egt probe and I have pulled the carpet back and I have found water around the wire harness any idea where it could be coming from it’s a 2013 model
Thanks Ron
516401
Triton n Lovin it.
From any grommet that isn't sealed properly, so shine a torch into the engine bay and visa versa to see any light.
Foo
Hi
Check your rubber air con drain seal on the firewall....
That could be perished and leaking condensation back in..
Troy I have looked at all seals they all seam good there nice and soft. Don’t see an aircon drain
I Have Imaginary Friends
Patrol Hybrid.
Have a read.
Your answer will be in here, somewhere.
Discussion Starter #7
Have a read.
Thanks argen2 I’ll have a read
Is there meant to be a hose come out of what looks like a grommet for the aircon drain
Triton n Lovin it.
Take a pic of what ya talkin about. ;)
Foo
Discussion Starter #10
516409
Behind that coil is where the air con drains from but there is no pipe coming out of it it all filled up with water again after running the aircon for 5 min
Triton n Lovin it.
Try here.
Foo
Discussion Starter #12
Try here.
Foo
This is what I have on the in side I can’t see a drain hose
516411
Triton n Lovin it.
Triton n Lovin it.
Found this on another site.
Hello,on the passenger side in the engine bay.The firewall curve to the bottom of the cab,at the top off the chassis rail you will find the outlet pipe.
Hope this help
Foo
Discussion Starter #15
Hi foo
I need to find it from the inside so I can put it back where it’s meant to go. I have found where it is meant to exit the fire wall but it looks like nothing is there
Triton n Lovin it.
This is the only thing that I've found so far. I don't have my Patrol anymore, so I can't check it out.
516412
Foo
Discussion Starter #17
Foo
Hi foo
Thanks for that but mine is nothing like that. My drain hole is in line with the grommet for the wire harness to go through and that white box in the post above looks like it’s in front of it
Triton n Lovin it.
I would think that the white box would be the holder of the condenser coil and water collector for the drain?
Foo
Stripped inside of ute for a tidy up and a bit better heat reduction, removed the factory sound deadening tar **** and found 2 x 10mm factory holes not sealed with anything more than sound deadening. That stuff does not seal so water was coming in underneath
1 - 20 of 23 Posts
