Thanks for the input guys,
Dual Fuel, I run on petrol every startup until engine warmup, then switch to lpg, When i run out of lpg i will just run it on petrol.
I had the flash lube at full flow, by what you guys say it sounds like i need a higher flow.
I did notice the higher the flow i had it on the engine actually ran rough, would that be because it wasnt mistyfied ?
I have found a hose that has been pluged on the intake pipes that i could pour a glass of water down,
How much water and how fast should i pour it ?
Should i expect the engine to get rough as im pouring the water ?
