1 - 11 of 11 Posts
Roads are for Toyota's
nissan patrol 4.2
So we had a little rain, I open my door and I find this. Only one side. Where the hell is it getting in? How do I stop it? Am I alone?
Maybe a long shot but check the drain holes in bottom off doors are clear. Small hacksaw blade fits well.
I've had that before.
You gotta close ya window when it rains.
Rogue
nissan gu patrol
Pic works for me.
I reckon drain holes being blocked too. Can you hear water in the bottom of the door when you move the door in and out?
Currently in PAD rehab
Pic works on my tapatalk. Must be a timo_ed bug :)
Yes I had that when I had window tinting and rust proofing done, the slackassholes just slashed the plastic inside the door trim and sliced off the inner lip of the window seal against the glass as they said it pushes the glass in and makes the tinting rub. The result was water running down the glass and dripping through my door speakers, then out under the trim.
They told me it cost them about $300 to replace the four door window seals and two wet speakers. But they just stuck packing tape over the inner door plastic slackfukers.
They also sprayed underbody stuff on the front hub swivels, this collected sand and destroyed the swivel hub seals, I never managed to get them or the Nissan dealer to come good on fixing that so have never been back to any of them for service or parts.
So I suggest, un block the door drain holes, take off the trim and check the plastic is not allowing water to channel down inside the trim.
nissan patrol 4.2
Thanks boys, I'll check it tomorrow.
My back door seems to fill up with water. When I open it, water runs out from the seal.. should fix that one day...
1 - 11 of 11 Posts
