1 - 15 of 15 Posts
That is what I would be using next time I buy a water tank.
Their (Manufactures - enmach industries for one) make some good tanks - I have used 3 before and all were very well made.
I'm not really a Newbie
This may be a silly question but do you leave them empty usually and just fill when needed?
I leave mine full so no crap grows in it, just like van tanks.
cheers DD.
Io think if the water is moving and sloshing around it should be ok, its only when the water is not moving it starts to get off ???
Ahh ok. Makes sense. Can you tell i have no idea 😊
If you intend to use plastic tanks for drinking water then it's wise to remove them on a regular basis and rinse with 'Milton' fluid or similar solution as used to disinfect baby bottles etc.
They are supposed to be UV stable and don't allow any light through that can promote bacteria growth etc but over time you will still get a slime on the inside that should be removed.
I much prefer tanks with port holes that allow you to get a fist inside for proper contact cleaning.
I do rinse my tank out from time to time but only about twice a year.
I use 25/75 off hydrochloric acid and water, takes any slime off instantly then rinse with water a few times and done. never had a problem with taste. I have been doing this with the caravan tanks for 15 years with no problems either.
cheers DD.
Discussion Starter #12
The people that do run them are they a gravity tap or do you have a 12 volt pump? And is the superior price what you would expect to pay for a full kit?
i have a 12v pump connected to mine, works a treat. i use flo jet pumps, they seem like a good, strong quality pump that has given me no problems in 5 years
Good pumps and you can get rebuild kits for them if needed
1 - 15 of 15 Posts
